Toymods » Tech & Conversions » AE82 GZE PEOPLE
Twinky
N.S.W
icon4.gif  AE82 GZE PEOPLE Wed, 19 March 2003 11:25 Go to next message
Hey, I need to know how you have set up you cross member. What mounts did you use and what brakcets that bolt onto the gear box did you use???
xpimp
melbourne
Re: AE82 GZE PEOPLE Wed, 19 March 2003 14:53 Go to previous messageGo to next message
Im doing this AS I TYPE Wink
I have used the GZE one on the top of gearbox, just machined off that stupid insert thingy that goes through the mount LOL but works real nice, will post some pics soon
and the ae82 one on the other side which also works VERY nice
but underneath i have problems, about 4-5cm spacer needed which either cross member Sad
Any answers ? or do i just keep makin up the spacers im doing
Do i use the AE82 xmember, thats what im planning on doing this weekend?
[Updated on: Wed, 19 March 2003 14:57]
Twinky
N.S.W
Re: AE82 GZE PEOPLE Wed, 19 March 2003 23:55 Go to previous messageGo to next message
Yeh I used both gze ones on the top (gearbox and near cam covers) I just cut down the tube that runs through them with a hack saw, they fit realy nice and snug Surprised
X member - Well With the gze brackets and ae82 x member there needs to be a spacer like 5-10cm, which is just gonna look farking rediculous. Before the conversion I was told 30mm which isnt so bad. Someone must know which mount brackets to use and which mounts to use.
Problem (2) - The passenger side driveshaft boot (inner one), sits really close to the body. If i tilt the motor slighty it moves away from the body. Would this harm the motor having it tilted like 10degrees or does it have to be dead straight?
xpimp
melbourne
Re: AE82 GZE PEOPLE Thu, 20 March 2003 00:52 Go to previous messageGo to next message
>Problem (2) - The passenger side driveshaft boot (inner one), >sits really close to the body. If i tilt the motor slighty it >moves away from the body. Would this harm the motor having it >tilted like 10degrees or does it have to be dead straight?
I dont have this problem :/ probably cause mines tilted slightly, however im pretty sure its straight... weird, have to look at that :/ ill take some pics on sat morn
The front only needs about 2 cm on my car, but the back needs atleast 5... are u sure ur engines not tilted already? cause im certain my driveshaft boot is sweet, and 10 cm happens if u tilt it the wrong way...
But yes this spacer is gonna be shocking, 5 cm on mine (plus rubber things is required) which is very bad Sad u cant use the gze xmember i tried it Sad and the only thing i can think of is turning up some hardcore spacers on the lathe
[Updated on: Thu, 20 March 2003 00:55]
Twinky
N.S.W
Re: AE82 GZE PEOPLE Thu, 20 March 2003 02:15 Go to previous messageGo to next message
Just put the cross member in temporary place. It looks like when the motor is straight, there is a 5-6cm gap between the cross member and body (at the back) and the front is like a 2-3cm gap. But with the motor straight the drive sharft boot hits the body Mad
The cross member is going to look fucking stupid hanging down so far. Mad Mad
Could someone with a AE82 GZE please help, some pics would be helpful to Crying or Very Sad
xpimp - have you done any wiring???
xpimp
melbourne
Re: AE82 GZE PEOPLE Thu, 20 March 2003 04:50 Go to previous messageGo to next message
I have split the looms and all i have to do is solder the new loom in... i am fairly confident that the electronics wont take me too long Wink I have labled every wire etc and just need to put it in
However that xmember does worry me too cause its gonna hang down heaps, lucky i dont have a lowered car
Twinky
N.S.W
Re: AE82 GZE PEOPLE Thu, 20 March 2003 10:19 Go to previous messageGo to next message
Bump.
Anyone thats done a gze into ae82 wanna come over an wire the cunt up with me?
rollaboy
Coffs
Re: AE82 GZE PEOPLE Thu, 20 March 2003 10:56 Go to previous messageGo to next message
Come on there's heaps of u's out there. Help a fellow TOYMODER.
[mikey]
Re: AE82 GZE PEOPLE Fri, 21 March 2003 04:49 Go to previous messageGo to next message
I did Mangew's AE82 with GZE, and it will depenmd what motor you're using. I used an AE101 engine.
The driver side chassis mount is AE82 with a spacer tube used for the bolt closest to the cam cover.
The passenger side gearbox chassis mount i had to modify to sit correctly, I used a 4AGE gearbox bracket and added a section to it for the third bolt, and slotted the holes to mount the engine at the correct angle, you can test this by the mount angles to the bracket, and pulley spacing from the chassis rail. actual mount is ae82 too.
x-member was an utter bitch, i used a 16mm spacer plate at the back when i had the engine sitting correctly. at the front of the 4agze box i used an ae82 rear gearbox mount bracket turned upside down and holes slotted slightly and std 4age front mount. rear i used the 4agze bracket and ae82 rear mount, i also had to weld a plate under the rear of the x-member and redrill the holes to the far edge of the x-member to line the mount up correct. similar with the front.
It is a pain in the ass.
Regards,
Michael
MaNGeW
Formerly TRD_RoLLa
Re: AE82 GZE PEOPLE Fri, 21 March 2003 09:28 Go to previous messageGo to next message
Thanks Mike
xpimp
melbourne
Re: AE82 GZE PEOPLE Sat, 22 March 2003 04:59 Go to previous message
Problem to note though the mags i had 13 inch dont fit Sad owww such a shame
I am using a AE92 halfcut and the xmember is a real bitch
Previous Topic:need help! Celica 182 3S-FE + supercharger from 1G-GZE
Next Topic:Where is my oil going???
Current Time: Sat Oct 24 01:38:26 UTC 2026
Total time taken to generate the page: 0.0045158863067627 seconds
