Classifieds » Miscellaneous » ct26 high flow
boost
MACKAY. QLD
ct26 high flow Thu, 20 March 2003 01:30 Go to next message
ct 26 high flowed by dts brisbane. new housing steel wheel/ shaft to4 comp wheel machined comp . offers around $1400 cost over this just to get work done . never fitted since rebuilt
wil8115
Seattle area, USA
Re: ct26 high flow Thu, 20 March 2003 10:58 Go to previous messageGo to next message
have all the specs?
which turbine?
which comp wheel?
is the turbine "clipped"?
Will
Re: ct26 high flow Thu, 20 March 2003 11:02 Go to previous messageGo to next message
Can I ask who dts brisbane is?
boost
MACKAY. QLD
Re: ct26 high flow Fri, 21 March 2003 00:08 Go to previous messageGo to next message
hope this helps guys
dts is dynamic turbo chargers (located in salisbury brisbane )and about 10 other places in aust.
the comp is a to4 with 54 mm inducer .exht is 50mm
it is the twin wastegate housing. comp ar well its a ct26.
will take $1250 no offers as this is new turbo (shaft steel wheel center housing) garretts are heaps cheaper to re build. warranty well dts give me one but dont know what happens when i resell privately.sorry hope this helps as i am keen to sell as selling my st205
trza2k
Re: ct26 high flow Fri, 21 March 2003 01:02 Go to previous messageGo to next message
What about the comp wheel size ?
boost
MACKAY. QLD
Re: ct26 high flow Fri, 21 March 2003 01:20 Go to previous messageGo to next message
guys like i said its t04 54mm comp inducer what else is it u need the major???? u need
trza2k
Re: ct26 high flow Fri, 21 March 2003 02:23 Go to previous messageGo to next message
The wheel size is very important, is there Anyway you can find it out? t04's come in a variety of sizes and the difference from a 54mm wheel to a 66mm wheel would be quite significant.
[Updated on: Fri, 21 March 2003 02:24]
boost
MACKAY. QLD
Re: ct26 high flow Fri, 21 March 2003 02:37 Go to previous messageGo to next message
sorry if not clear but try again its a 54mm inducer u should know what that is. do you need the major? its either a 2.75or3.0 inch.
Re: ct26 high flow Fri, 21 March 2003 06:33 Go to previous messageGo to next message
boost wrote on Fri, 21 March 2003 10:08
Thanks for that mate.
SUPRAGTE
North Sydney
Re: ct26 high flow Sat, 22 March 2003 03:22 Go to previous messageGo to next message
TRZA2K he is saying its a 54mm inducer or comp!!!
trza2k
Re: ct26 high flow Sat, 22 March 2003 03:37 Go to previous messageGo to next message
The Inducer is the size of front inlet allowing air into the compressor wheel isnt it?. I wanted to know the actual wheel size inside the compressor? And from what i gather its just a new ct26 cover?
Am i making sense?
[Updated on: Sat, 22 March 2003 03:41]
TE72_Turbo
Re: ct26 high flow Sat, 22 March 2003 12:32 Go to previous messageGo to next message
most specification data for turbo compressor wheels will refer to the wheel measurements as "inducer" and "major" for the front & rear diameters respectively.
Phil
trza2k
Re: ct26 high flow Sun, 23 March 2003 08:44 Go to previous messageGo to next message
Yes it seems with a t04 it is the case, thanks for clarifying.
boost
MACKAY. QLD
Re: ct26 high flow Wed, 02 April 2003 00:50 Go to previous messageGo to next message
sorry all forgot to mention it is twin entry exht housing.will take 1100 for it must sell to finance new garrett
also have a rare ct20b off my st205 done 75k open to REALISTIC OFFERS. thanks
spectral
Re: ct26 high flow Wed, 02 April 2003 06:14 Go to previous messageGo to next message
what engine is it off?
Gen 2 3SGTE? (a la ST185 Celica?)
GEE120
Re: ct26 high flow Wed, 02 April 2003 08:58 Go to previous message
Yeah, that is definatley off a ST185, cause the st165 ct26 is single entry
Previous Topic:3SGE Gen 1 and RWD gearbox to suit.
Next Topic:RA28 Celica Shell and Panels
Current Time: Sat Oct 31 08:44:14 UTC 2026
Total time taken to generate the page: 0.11298203468323 seconds
