| Author | Topic |
Phill's RA23 Celica
Wed, 15 May 2002 05:38
MODEL 1976 RA23 Celica
COLOUR Blaze blue (soon to be white!)
ENGINE 1989 GZ20 Soarer 1GGTE, 13psi, HKS Powerflow filter, 3" exhaust
BRAKES Front-Peugeot 604 11" vetillated discs, Hilux 4 piston calipers on Corona XT130 struts Rear- standard Hilux drums GZ20 1" bore master cylinder
SUSPENSION Front:- Pedders springs and shocks Rear:- Pedders springs and shocks, Selby sway bar
DRIVELINE W57 gearbox, 3" single piece tailshaft, shortened Hilux LSD, re-ratioed to 3.9:1, LSD tightened +20%, standard 30 spline axles, restudded to Celica pattern
OTHER BITS GZ20 twin core aluminium radiator,10" & 12" thermos mounted behind radiator, Recaro seats, Autometer boost gauge, TurboXs fine/coarse adj. bleed valve, custom centre console, Sony CD player
FUTURE MODS/FIDDLINGS.....(by the end of November) -fit R31 rear disc brakes in place of Hilux drums, along with bias valve -Detroit True Trac LSD centre -fit slotted discs to front with Nissan 200SX Ultimate pads -get coil overs built for the front, fit with Koni adjustables -fit my adjustable strut tops -adjustable panhard rod and rear sway bar -full respray with all locks removed, aerial removed etc, in 2pac white -custom 1" exhaust manifold with 2 x GTR N1 T28's sitting on top of it, 2.25" separated dump pipes -MoTec M48 Pro ECU with MoTec (Bosch) boost controller -custom twin entry/single outlet bar and plate intercooler with associated piping -aluminium radiator header tank -oil/air seperator -sit motor lower and further back in engine bay -fit W58 with short shifter -upgrade fuel system using 600hp Bosch pump, Carter lift pump. 3/8" lines and Malapsi rising rate regulater -hide/rewire engine bay wiring (chassis wiring) -new 16" wheels Simmons F90's
[Updated on: Sun, 23 June 2002 11:18]
Toymods Board Member I supported Toymods
Re: Phill's RA23 Celica
Thu, 13 June 2002 02:24
Hey dood,
With your speedo and tacho, how did you get it do give you the correct readings, or have you not fixed/calibrated it yet ?
I did a 1g conversion into my ra65 and the speedo is stuffed.. Called up a mechanic and he wanted $150 to fix it for me. Is this reasonable/correct?
UPDATE!!
Sun, 14 July 2002 06:43
As alot of you know, the car is being rebuilt. So far it is a bar shell, with all the rust holes welded up and almost ready for a respray. I completed the engine bay wiring, and now there is not 1 wire that runs between the chassis loom and the motor (there is no chassis loom anymore ), and hidden all the wiring. The door locks have been removed, and ive made a cable boot release. Also, removed all the shit factory items off the motor, to make way for the MoTec. Done some more weight reduction by taking out the rest of the sound deadening (tar) shit, and any wiring that is usless, and the anchor of a rear parcel shelf.
If i figure out how to put up pics, i will obviously put a heap up!!
Re: UPDATE!!
Wed, 24 July 2002 16:47
Hi guys,
I'm looking for some parts for my '77 Celica Coupe GT, if you guys can give me some help, I'll be very appreciate that, I'm living in U.S., Boston (I know it's far from you guys, but I'm helpless here man !) the parts I'm looking for is following please help !!
1. Aussie style Front and Rear bumpers.
2. Front indicators (R & L).
3. Front (R & L) bumper and indicators hinge arms.
4. Front 3 metal plates (between front grill and bumper those plates).
Thanks buddy !!
Peter (p.s. my e-mail : toyocelica@hotmail.com)
Sun, 29 December 2002 05:51
OK all, here is an entire list of mods/changes ive done to the car in the 6 months its been off the road....
ECU:- Motec M48 Pro, Motec boost controller, Motec dual stage shift light, wired it up for full sequential operation, clutch switch (IG cut for flat changes), and a few other minor things
INDUCTION:- custom 1" steam pipe exhaust manifold, split in 2 (front 1/2 and rear 1/2), port matched to suit 1GGTE exhaust ports, black ceramic coated, 2 x R33 GTR T28 turbos w/steel exhaust wheels, black ceramic coated ex. housings, braided oil feed lines with fire shielding, custom water lines with fire shielding
INTERCOOLER:- core = 500x300x75mm bar and plate, custom end tanks with 2.5" inlet & outlets, dual 1.5>2" off each turbo into single 2.5" pipe, 2.5" pipe from i/c to throttle body, Turbosmart Type 2 BOV
FUEL SYSTEM:- Bosch 600hp external EFI pump, Facet lift pump, 3/8" (10mm) lines throughout, Malapassi Rising Rate regulater, 6 x 7MGTE 440cc injectors
DRIVETRAIN:- W58 gearbox with shortshifter, rebuilt and shortend 3" tailshaft, 5 puck solid brass button friction plate, 630kg pressure plate, braided clutch line
OTHERS:- NO engine bay (chassis) wiring, all hiden or removed, boost gauge in drivers side air vent, 5% tint windows (too dark really), all rust removed and welded up, resprayed Toyota "Ice Blue", door locks removed, aerial removed, 6" cold air duct hiden, KE30 washer bottle, and a HEAP of other stuff i cant remember..
STILL TO DO:- 3.7:1 gears to diff, fit JZA70 Torsen centre, Skyline rear disc brakes, slotted rotors, front coil overs, air conditioning, new head unit with front 2 speakers ONLY, radiator header tank, oil cooler, fit Motec Traction Control Multiplexer with 3 wheels sensors, LAMBDA software and exhaust sensor for Motec, etc, etc...
I hope this saves me some heartache at explaining all this to everyone, cos im getting tired of being asked the same question over and over again
Sun, 29 December 2002 06:49
Sounds dam tough mate !!
I hope that you have it at the dyno day (so we can all cheak it out) even if you dont run it!!
Thu, 26 June 2003 09:01
If you give me the photos of your car I'll host them...
I just want to see what it's like
| Current Time:
Fri Nov 20 11:26:44 UTC 2026 |
Total time taken to generate the page: 0.0055999755859375 seconds |
