Toymods » Tech & Conversions » alternator problems
RA28
alternator problems Fri, 21 March 2003 13:27 Go to next message
I am having alt troubles in my little torana, I think it is cactus. It s an old, externally regulated unit. I have another one but it is internally regulated I think, it only has the B+ and N (charge light) connections. If I put this one in and connect the 2 wires, the car runs on it alone, but dies when the lights are turned on (no battery connected).
The old alternator had a B+, a N and a F.
Can anyone tell me how to connect the internal reg. alt. to the old girl??
Thanks, Tim.
pedroenglish
Re: alternator problems Sat, 22 March 2003 04:00 Go to previous messageGo to next message
The new Alternator has just one power connection B+ which goes straight to + side of battery.(follow the lead)
Disconnect the external regulator.
The N is the connection for the charge warning light in the dash...you don't need to connect this to get the alternator working.
Don't run the motor with battery disconnected you can do real damage to car electrics!
To test the alternator: measure battery volts..13.8 approx is charge volts, look for this when fast idle and lights on (and also off too).
ROBBO_ma61
Re: alternator problems Sat, 22 March 2003 04:02 Go to previous messageGo to next message
didnt toranas use generators, not alternators?
juzzo84
Hornsby, N.S.W
Re: alternator problems Sat, 22 March 2003 07:28 Go to previous messageGo to next message
my mates have had all types of torrys and i have never seen on with a generator.
justin
RA28
Re: alternator problems Sat, 22 March 2003 07:50 Go to previous messageGo to next message
Torana's had both, the very old ones had generators Thanks for the help with the alternator.
So internally regulated units only really need the B+ to the battery. Why did my 1ggte alt have lots of connections on it?
ROBBO_ma61
Re: alternator problems Sat, 22 March 2003 08:46 Go to previous messageGo to next message
just changes in technology man....toyota mustve think they might be useful for something...if you alternator is rooted just buy a 89-94 commodore/ falcon one...cheaper and better..or i have one for sale off a 5me Smile
Re: alternator problems Sat, 22 March 2003 09:13 Go to previous messageGo to next message
i don't suppose anybody knows what >70amp alternators use the same mounts/pulley/pulley-offset/case-size/etc as those used on 18R?
and what models/engines they come out of?
I would like to bump capacity from the 45-50amps available from my standard (exchange) unit to something pumping out 70-80 amps? and not rely on an external regulator?
Am moving to EFI (megasquirt) and EI (megajolt-light) and think the two CPUs will require more stable & studier power than my current uinit provides.
ta.
RA28
Re: alternator problems Sat, 22 March 2003 09:33 Go to previous messageGo to next message
Um, dude, I don't think your 2 computers are going to need 70 amps!!
Pretty sure your stock electrics should be able to run the comps, maybe if you ran big coil packs (and lots of them). You'd only really need a big alt for big stereo gear, or some kind of huge custom lighting display or something. 70 amps is a lot of power...
Tim.
Re: alternator problems Sun, 23 March 2003 05:01 Go to previous message
yes, maybe 70A is a bit over the top, tim Wink
... but i'll need to power:
coil packs, 2 x CPUs, 4 injectors, bigger fuel pump, elec fan, etc
none of which the original electrical system was designed to accomodate.
and most of it needs 12V regardless of electrical load (e.g. rainy night, demister+wipers going flat-out, lights on hi-beam, etc... ).
however, your concern about my willingness to over-engineer is appreciated Wink
ta.
Previous Topic:AE86 IDEAS
Next Topic:AE-92 4AFE to 4AGE
Current Time: Fri Oct 23 18:43:22 UTC 2026
Total time taken to generate the page: 0.01121997833252 seconds
