Toymods » Tech & Conversions » RA65 Suspension Upgrades
trd_celica85
Modbury, SA
icon3.gif  RA65 Suspension Upgrades Sun, 23 March 2003 02:53 Go to next message
Heyas,
The rear suspension on me celica is absolutely shagged so im looking at replacing the shocks and using lowered springs. What can you guys suggest as the best shock/spring combo for front and rear that will get me the bets ride and at what price??? Is there anything that can be done to stop the rear end boggin down when taking off hard or should the new suspension pretty much stop it??? and also can anything be done to combat the camber on the rear once lowered???
Just another thing, i've seen in the US some guys have swapped the rear end off a supra into their celicas to use the LSD and rear disks, has anyone tired that here??? im looking at doing it soon and just seeing how much its gonna cost??? would my w55 box still be alright or should i look for a w58??? and if i get new suspension now will it still suit the supra rear end?
Aden.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: RA65 Suspension Upgrades Sun, 23 March 2003 22:56 Go to previous messageGo to next message
Koni shocks are awesome value. Highly recommended.
For springs, K-Mac do them, but they're damn firm. Depends on what you want, I love em. Smile
celicamad85
Banned member
Re: RA65 Suspension Upgrades Mon, 24 March 2003 01:53 Go to previous messageGo to next message
the supra rear end with the disc brakes is a straight swap....afternoon job
trd_celica85
Modbury, SA
Re: RA65 Suspension Upgrades Mon, 24 March 2003 02:52 Go to previous messageGo to next message
Thanks guys,
Nark, how much can i expect to pay for koni shocks and kmac springs??? i want a fairly hard ride, will they stop the rear end boggin down?
celicamad85, how hard is it to find a rear end and how much?? would the brakes be hard to hook up?
Cheers again
Re: RA65 Suspension Upgrades Mon, 24 March 2003 03:14 Go to previous messageGo to next message
The IRS subframe is attached to the floorpan with 4 big bolts. Basically you disconnect the tailshaft and brake lines, undo the 4 bolts, and the whole subframe drops out. Swap in the Supra subframe, re-connect everything, and you're done! It would be a very straightforward job for a suspension shop.
As for brakes, you may need to get rid of the proportioning valve for the drums when you convert to rear discs... not sure on the specifics with that though. You may also need to change the master cylinder?
celicamad85
Banned member
Re: RA65 Suspension Upgrades Mon, 24 March 2003 04:11 Go to previous messageGo to next message
i paid $400 for the complete rear end including shocks and springs from the wreckers
it was a straight swap from memory apart from having to do something small to the brake lines either move them a bit or add a bit of hose
Nark
Cabramatta, NSW
Re: RA65 Suspension Upgrades Mon, 24 March 2003 04:57 Go to previous message
trd_celica85 wrote on Mon, 24 March 2003 13:52
Hmm... Can't really remember. I think the springs were $310 per pair.
Try http://www.k-mac.com.au/
The Konis were from Wholesale Suspension in Penrith. Can't remember how much it was, about $250 for a pair I think.... They were the cheapest that I found.
You can get them on (02) 4721 2112.
Firm springs will minimise the squat. My car is damn flat through corners, very nice. Big swaybars help too.
Previous Topic:broken coupling - 3s-ge in sv21 camry
Next Topic:AE82-Drum to disc rears, what do i need?
Current Time: Fri Nov 20 13:35:20 UTC 2026
Total time taken to generate the page: 0.0073041915893555 seconds
