Toymods » Tech & Conversions » Quick question re: brakes.
biased99
Quick question re: brakes. Sun, 23 March 2003 23:09 Go to next message
Hi Guys,
I have an opportunity to purchase some 300MM Rotors and calipers from a MK3 Supra, and am wondering whether they will fit on our MX83 Cressida...I assume they will need some kind of modification; I just need to get an idea of how much "modding" will be required...If it is very costly to do, I may not bother if, however, it can be done relatively easily, then it is probably worthwhile.
N.B. I have to decide today so prompt replies would be appreciated... Smile
Re: Quick question re: brakes. Sun, 23 March 2003 23:25 Go to previous message
I'd imagine it's unlikely to be a direct bolt on mod. Offset of rotors is significantly different (53mm for Cressi vs. 68mm for Supra). Also, given the large increase in rotor diameter (256 to 300mm), I'd imagine it's unlikely the calipers mounting holes will be in the right spot for the upgrade. Of course, there may be a difference in the calipers that allows for such an increase in rotor offset and diameter.
I suggest you check before you buy (or not buy) if possible....even do a basic trial fitting if the seller allows. Sorry I can't give you a definite yay or nay.
Previous Topic:4AGZE Emissions Test results, where to find??
Next Topic:weatherstrip on MA61
Current Time: Sat Oct 31 12:55:43 UTC 2026
Total time taken to generate the page: 0.045925140380859 seconds
