Toymods » Tech & Conversions » W58 Gearbox fluid
stradlater
Arthurs Creek, Victoria
W58 Gearbox fluid Mon, 24 March 2003 09:43 Go to next message
What sort of fluid should I use for the w58 Gearbox, where should it be filled from and how much does it take?
VB gze
Gosford
Re: W58 Gearbox fluid Mon, 24 March 2003 09:59 Go to previous messageGo to next message
It takes about 3.8L of a synthetic fluid that can handle a LSD. if you use non LSD oil you could destroy it. I use Syntrax by Castrol 85W/90 and as far as i am aware it is the only non-genuine oil.
VB gze
Gosford
Re: W58 Gearbox fluid Mon, 24 March 2003 10:00 Go to previous messageGo to next message
VB gze
Gosford
Re: W58 Gearbox fluid Mon, 24 March 2003 22:09 Go to previous messageGo to next message
SOrry i was talking about a E-58 front driver box. Not sure what a w58 is.
crostek
Oyster bay NSW
Re: W58 Gearbox fluid Tue, 25 March 2003 01:30 Go to previous messageGo to next message
it takes about 2lt to fill / replace it.
you fill it from the side of the box.
19-21 mm filler plug passenger side from memory
Purple_Beasty
New Zealand
icon5.gif  Re: W58 Gearbox fluid Tue, 25 March 2003 01:53 Go to previous messageGo to next message
crostek wrote on Tue, 25 March 2003 13:30
Just curious, has anyone filled a W58 through the gearlever? Usually easier than trying to get the damn filler plug out while lying under the car and then spilling oil everywhere while trying to fill it.
Callum
Re: W58 Gearbox fluid Tue, 25 March 2003 04:07 Go to previous messageGo to next message
I always fill from the gear lever, it's much easier. You just have to be careful not to spill any of that stinky gear oil on your carpet!
CelicaRA45
nth ringwood, Victoria
Re: W58 Gearbox fluid Tue, 25 March 2003 08:22 Go to previous messageGo to next message
toyota say in my manual 2.8 liters for w58 supra box
ROBBO_ma61
Re: W58 Gearbox fluid Tue, 25 March 2003 08:58 Go to previous messageGo to next message
yeah it takes a bit less than 3L. I use penrite hypoid gear oil, and it seems to work fine, so id reccomend it!
suprav8
melbourne
Re: W58 Gearbox fluid Tue, 25 March 2003 09:08 Go to previous messageGo to next message
I use 2 litres castrol 85w/90 gearbox oil with 500 ml trans fluid.....and always fill through the gear lever hole!!!!!!!
Re: W58 Gearbox fluid Tue, 25 March 2003 12:21 Go to previous message
I always fill through the gearstick hole, and if I don't know how much to put in leave the check plug out, slowly pour it in, and wait till oil comes out the hole Very Happy
As for mixing ATF/gear oil, do you find it helps the shift? Last manual box I did (not a toyota) I used all ATF with some auto trans additive - worked WONDERS for shift quality. However, I'd be sceptical of using too much ATF in a highly stressed box - preferably stick to a basic type gear oil, preferably also avoiding synthetics and anything too thin, after seeing what they do to a lot of diffs!
Previous Topic:2tg timing chain tensioner???????
Next Topic:Toyota Nationals WHO IS COMING???
Current Time: Thu Oct 29 20:50:51 UTC 2026
Total time taken to generate the page: 0.005897045135498 seconds
