Toymods » Tech & Conversions » WTD 20V info
neat 20valve
WTD 20V info Mon, 24 March 2003 23:19 Go to next message
Hi all im in need of some 20 valve (silver top) info, mine is running like a dog i think my rev limiter is retarding its self some how. what is the standard rev limit on a stock computer.
would it help to have it dynoed or just get it tuned? all info
greatly appreciated.
haggis
Re: WTD 20V info Tue, 25 March 2003 02:22 Go to previous messageGo to next message
i belive the rev limit standard is about 7400.
A good tune can never hurt, but its good to get the the source of the problem first!
Try swaping the computer with another standard one if you can.
Craig.
jasonp1977
Re: WTD 20V info Tue, 25 March 2003 06:21 Go to previous messageGo to next message
Stock rev-limit is around 8250 if the engine is wired correctly... you need the purple wire with white stripe on the 12 pin plug of the ECU connected to a speed sensor output from the dash cluster in order for it to cut at the correct limit.
Jason
neat 20valve
Re: WTD 20V info Tue, 25 March 2003 22:29 Go to previous messageGo to next message
Thanks for all your help guys.
jkvsnn
Re: WTD 20V info-rev limit 7500?? Sun, 26 September 2004 01:28 Go to previous messageGo to next message
I have just last week bought an AE92 CSi Hatch that has had a 20v conversion.
The dash in the car is (I'm assuming here) the CSi dash (gauges), small fuel gauge on left, 180 KPH speedo, tacho which reads to 8000 but redline is marked at 6000 (IIRC) and on the right a non functioning temp gauge Sad .
I have noticed that the rev limiter cuts in at around 7500 and a search here on toymods has revealed that there is a wire on the ecu that needs to be connected to the speed output on the cluster. Do the standard CSi gauges have this output? where would I find it? If they don't whats the solution, find some 20V guages?
Thanks in advance,
Julian
Brisbane.
NuGeN
Re: WTD 20V info-rev limit 7500?? Sun, 26 September 2004 03:55 Go to previous messageGo to next message
Is it a CSi? or a CSi Limited? Because CSi's didn't have stock tacho's. Does your cluster have an EFI engine light? If it does it should have the purple wire speed sensor wire.
jkvsnn
Re: WTD 20V info Sun, 26 September 2004 12:15 Go to previous messageGo to next message
Yes it is a CSi limited.
Thanks for the info.
It never ceases to amaze me just how useful these forums are....how on earth did things get done before the internet??
Cheers Julian.
EvilJack
Sutho/Hills NSW
Re: WTD 20V info Sun, 26 September 2004 12:50 Go to previous messageGo to next message
http://www.twincam.org/forums/index.php?showtopic= 397
jkvsnn
Re: WTD 20V info Tue, 05 October 2004 12:52 Go to previous messageGo to next message
Hmmm, actually a CS limited, no "i", car was born with a 4AC.
No purple wire to the dash cluster. Is there a different wire to look for or do I have to do whats shown in eviljacks post?
Julian
Re: WTD 20V info Tue, 05 October 2004 13:16 Go to previous messageGo to next message
the 4 pulse per revolution output is there, fuck its even there on an AE71!
open up the cluster and look for a spot on the PCB labelled "4P"
thats what you want connected to the SPD pin on your ECU. problem solved.
jkvsnn
Re: WTD 20V info Tue, 05 October 2004 13:24 Go to previous messageGo to next message
Aha! Will have another look. Need those extra 850RPM. Want to beat my friends Integra VTiR Twisted Evil
Thanks.
Julian.
jkvsnn
Re: WTD 20V info Tue, 26 October 2004 07:00 Go to previous messageGo to next message
Had the opportunity to take out the gauges today.
On the back of my gauges there is a flexible plastic PCB(?) that has barely anything marked on it. The first and last pin for each of the three plug sockets is marked but thats about it.
Where do I find the 4P??
BTW. There is a fourth plug off the gauges loom that goes to nothing (at present) and I can't see what that would plug into.
Is it for the extra gauges of an SX dash?
Julian.
Johnny
Sydney, OZ
Re: WTD 20V info Wed, 27 October 2004 05:52 Go to previous messageGo to next message
slowly...
jkvsnn
Re: WTD 20V info Wed, 27 October 2004 13:06 Go to previous message
no response to the location of the 4P point?
I found out today what the forth plug in my dash loom was when refitting the plastic centre console trim.....rear window wiper and demister switch Embarassed
Oops,
Julian
Previous Topic:AW11 4AGZE
Next Topic:1jz into a ma70 supra with 7m-ge
Current Time: Sat Nov 21 01:50:46 UTC 2026
Total time taken to generate the page: 0.0061259269714355 seconds
