Toymods » Tech & Conversions » Help: what to do when u cant get fuel filter out
TWSTD
Auckland, New Zealand
Help: what to do when u cant get fuel filter out Tue, 25 March 2003 03:15 Go to next message
Ive had my car in 2 workshops now and neither could remove the bottom nut on the fuel filter. I need to change the filter but noone can get the old one out. As a result of their efforts the nut is now rounded Crying or Very Sad
Any suggestions on what course of action to take? Im assuming i will have to cut the thing out - but then there will be the issue of attaching the new filter...
Suggestions appreciated.
DannyGT4
Toymods Board Member
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 03:30 Go to previous messageGo to next message
mmmm if they rounded the nut themselves then i would've thought that they'd fix the problem they caused - i would have insisted
sounds like they couldn't be bothered
what sort of car??
TWSTD
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 03:34 Go to previous messageGo to next message
Yeah - well i think the first workshop were the main culprits for the rounding - trouble is that was sort of an aquaintence who was doing a favour for me and doesnt have the means to fix it... The 2nd workshop basically dont want to do - they told me they "dont have time this week and maybe contact them next week"
The car is a 1997 toyota carib. (a corolla wagon but 4wd).
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 04:02 Go to previous messageGo to next message
If possible, weld another big nut onto the existing nut and undo it that way. I'm not sure if it's safe to do this if it's close to the fuel lines, but it's worth considering.
rob_RA40
c'town, NSW
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 04:12 Go to previous messageGo to next message
with all the electrics in the car will it be safe to weld something connected to the chassis/body?
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 05:32 Go to previous messageGo to next message
Yes it's safe, provided you disconnect the battery before you start welding.
rvrolla
Central Coast
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 13:00 Go to previous messageGo to next message
TWSTD wrote on Tue, 25 March 2003 14:15
You need the Danoz Direct SUPER WRENCH!!!!!!!!
It will undo anything, even stripped bolts!!
I know, I watch too much late night telly, sorry... No No No
[Updated on: Tue, 25 March 2003 13:01]
clubagreenie
1st street on the right
Re: Help: what to do when u cant get fuel filter out Tue, 25 March 2003 21:40 Go to previous messageGo to next message
Try a stud remover. It will probably need a fairly large one I guess but same type of removal. Any sort of spanner with a camming action to grip it should work.
Replace the lower pipe as well as the filter.
Bypass to a different filter.
1jdave
Re: Help: what to do when u cant get fuel filter out Fri, 28 March 2003 21:42 Go to previous messageGo to next message
the 1st thing is to order the new nut so u dont have 2 use the old 1 im not familiar with this model but im sure someone with skill would be able to remove it.
shinzui
Re: Help: what to do when u cant get fuel filter out Sat, 29 March 2003 00:18 Go to previous messageGo to next message
If all else fails, you can do what I did with my stripped pulley bolt. Get a grinder and grind it down so its not rounded anymore Smile
You then just use a smaller socket/spanner.
Grega
melbourne.victoria.austra...
Re: Help: what to do when u cant get fuel filter out Sat, 29 March 2003 13:37 Go to previous messageGo to next message
yeah, but u gotta remember this is on a fuel line...
i dunno if you'll be able to get em in there, but, MULTIGRIPS seem to work well on them there rounded bastards...
CLG
Perth, Western Australia
Re: Help: what to do when u cant get fuel filter out Sat, 29 March 2003 13:53 Go to previous messageGo to next message
Are they attacking the nut from the engine bay or from under the car? Have a friend with a similar setup - he had to take the car to a mechanic friend, put it in the hoist, and swing a damn big breaker bar off the nut to crack it.
I have a "speed wrench" good for stripped nuts, again a cammed setup suitable for any size nut, that has teeth that bite into the worn sides. If you can find one, it will become an invaluable tool in your kit!
rollaboy
Coffs
Re: Help: what to do when u cant get fuel filter out Sun, 30 March 2003 08:35 Go to previous messageGo to next message
Couldn't you just hack saw the the filter off and replace it with a inline fuel filter and attact the filter to the metal fuel lines with rubber lines and clamps??
EvilJack
Sutho/Hills NSW
Re: Help: what to do when u cant get fuel filter out Sun, 30 March 2003 08:54 Go to previous messageGo to next message
i banged a smaller ring spanner over the bolt to undo a rounded bolt.
CLG
Re: Help: what to do when u cant get fuel filter out Sun, 30 March 2003 09:48 Go to previous messageGo to next message
I "banged" a good looking blonde once, ..., come to think of it, I've hit on a few too Shocked
GTI16V
CROMER, NSW
Re: Help: what to do when u cant get fuel filter out Sun, 30 March 2003 10:53 Go to previous messageGo to next message
Buy the replacement filter and cut the fuel line further down the car , flair the pipe buy some efi rubber hose and use a hose clamp to attatch it (commodores are like this) buy a screw in adapter for the replacement filter and screw it in put hose and hose clamp and attatch.Or you could buy a new fuel line from toyota .Filter change done.
[Updated on: Sun, 30 March 2003 10:54]
TWSTD
Re: Help: what to do when u cant get fuel filter out Sun, 30 March 2003 20:38 Go to previous message
Cheers all for the suggestions. As the nut was so hard to get to (only really accessible from the wheel arch) and vice grips didnt help i ended up cutting the fuel line a couple cm before the filter, buying a banjo nut with a hose barb fitting and joining it a;; up with flexi fuel line and hose clamps - seems sweet as.
What pisses me off is that the two garages / workshops i took the car to could come to this solution. Just reconfirms my lack of trust in so called "professionals" - think i'll stick to doing as much work on my own car as humanly possible (along with the help of the Toymods crowd from across the ditch Wink
AL
Previous Topic:20v Wiring loom
Next Topic:3S-GTE INTO 1988 SX Celica
Current Time: Sat Oct 24 11:47:07 UTC 2026
Total time taken to generate the page: 0.006810188293457 seconds
