Toymods » Tech & Conversions » Twin entry turbo/single entry turbo - Differences
Classique71
Colac, Victoria
Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 10:09 Go to next message
Still learning about the snails
Whats the difference between a st185's twin entry setup - to a single entry setup for other ct26 turboed cars ..
help me learn - please :)Smile
TE72_Turbo
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 10:40 Go to previous messageGo to next message
single entry CT26, such as the ones on 7MGTE's and "apparently" some early 3SGTE's have a conventional exhaust housing with one inlet combining the exhaust flow from all cylinders. There is a single wastegate port & flap within the housing to control boost. This is simple to manufacture, and fairly compact.
The twin entry CT26 has (naturally Smile) two inlets in the exhaust housing. these pair the flow from cylinders 1&3, 2&4 through the manifold design, splitting them to meet the turbine wheel 180 degrees apart. This way the exhaust gases 'hit' the turbine in two places with alternating pulses due to the grouping of the cylinders, improving the spoolup time. The added advantage is that there is a substantially sized wastegate port & flap for EACH of the two inlets, allowing much more bypass air to be flowed for excellent boost control at higher boost pressures.
clear as mud? Very Happy
Phil
Classique71
Colac, Victoria
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 10:43 Go to previous messageGo to next message
thanks Wink
in other words - twin entry spools more efficiently Wink
TE72_Turbo
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 10:48 Go to previous messageGo to next message
If used properly with a paired manifold, then yes.
Are you planning an upgrade already?
Classique71
Colac, Victoria
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 11:04 Go to previous messageGo to next message
Gt4's have it already - dont need to upgrade ..
just wanted to know the difference
TE72_Turbo
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 11:12 Go to previous messageGo to next message
thought you might be getting an ST205 CT20B turbo perhaps....
Classique71
Colac, Victoria
Re: Twin entry turbo/single entry turbo - Differences Tue, 25 March 2003 11:16 Go to previous message
noo - not yet by a long shot Smile
if i upgrade - ill just highflow the ct26 with a to4 turbine Wink
Previous Topic:Toyota Nationals WHO IS COMING???
Next Topic:What is a 2JZ-FSE??
Current Time: Thu Oct 29 12:59:18 UTC 2026
Total time taken to generate the page: 0.067111968994141 seconds
