Toymods » Tech & Conversions » which tranny for 3sgte conversion into st162?
benmeyer
which tranny for 3sgte conversion into st162? Tue, 25 March 2003 12:25 Go to next message
Obviously i cant use a GT4 box and the ones that came with the st162s are waaaaay too short, not to mention it would shit tiself after a while. anybody have any ideas who has done this conversion. i know there are a few of you guys running blown 162's out there. HELP!
thanks guys
Necros
Re: which tranny for 3sgte conversion into st162? Wed, 26 March 2003 04:00 Go to previous messageGo to next message
Read this thread, a st182/184 celica w/ a Grp A GEN II 3S-GTE w/ SW20 LSD.
http://www.toymods.org.au/msgboard/index.php?t=msg &th=10805&rid=1354&S=1b98841185e087729 ff6905c6ab4cf61&pl_view=&start=0#msg_89676
CeLiCa
Re: which tranny for 3sgte conversion into st162? Wed, 26 March 2003 06:02 Go to previous messageGo to next message
If u dont understand what it says in the post, PM me and ill try to explain what u need to do...
benmeyer
Re: which tranny for 3sgte conversion into st162? Wed, 26 March 2003 11:17 Go to previous messageGo to next message
Yeah if you could explain that in english it would be great.
CeLiCa
Re: which tranny for 3sgte conversion into st162? Wed, 26 March 2003 11:32 Go to previous messageGo to next message
Ok, these are the parts that u need:
MR2 turbo gearbox
Inner ends of MR2 driveshafts
Outer ends of GT4 driveshafts
Selector forks and cover from GT4 gearbox
Braket to hold selector cables to gearbox from GT4 tranny
This is how u do it:
The MR2 gearbox bolts straight onto the GT4 3SGTE so this part is not the problem. You need to swap the MR2 selector forks with the GT4 ones because the MR2 ones are on the wrong side of the gearbox. Up to now its fairly easy other than these two holes that need to be drilled and taped. Modifying the driveshafts isnt too hard either. Both the GT4 and MR2 ones come apart into two pieces and the pieces are interchangable as they have the same bolt pattern. Bolt the MR2 inner ends (part that goes into gearbox) to the GT4 outer ends (part that goes into hub). The axels might be slightly long so u might need to angle grind the ends. One problem i had was that the gearbox mounts didnt line up properly. I had to get them modified to fit. If you ever need to do this swap, PM [mikey] and get the detailed instructions of him. He gave me all the info i needed for the swap and he knows his stuff...
benmeyer
Re: which tranny for 3sgte conversion into st162? Fri, 28 March 2003 01:10 Go to previous message
Thanks mate, that was really helpful. now to source the parts. I'll PM Mikey about it too.
Previous Topic:Recommendations for sway/stabilzer bar.
Next Topic:Anyone know of any upcoming dyno days in sydney
Current Time: Mon Nov 2 06:08:06 UTC 2026
Total time taken to generate the page: 0.0060360431671143 seconds
