Toymods » Tech & Conversions » turbo oil-seals
Chriph
turbo oil-seals Wed, 26 March 2003 08:51 Go to next message
Been noticing a reasonable amount of oil making its way past the seals on my turbo recently (well for a while now...). It's a ball-bearing garrett t3 (from the vg30 engine), I've heard these can't be rebuilt but is it possible to change the oil-seals? If so is it worth it (price wise or in terms of longevity)? Any advice would be much appreciated. Cheers, Chris.
TE72_Turbo
Re: turbo oil-seals Wed, 26 March 2003 11:00 Go to previous messageGo to next message
hey chris
is it leaking out the exhaust side, or past the compressor wheel into your inlet?
I 'think' Smile replacing the seals is not going to be much simpler than a full rebuild anyway. You still need to take the whole shaft out & beadblast it where the ring seal on the exhaust side fits to remove the carbon buildup, then you're up for a balance (I paid $130 just for the balance) once its back together.
Maybe its time to bolt a GT30 in its place Very Happy
Phil
Re: turbo oil-seals Wed, 26 March 2003 11:01 Go to previous message
Some turbo places WILL have a go at these turbos - but a couple of important things first - are you using the correct oil restrictor, is your drain back adequate, and are you SURE there's no positive pressure in the crankcase - preferably negative.
Previous Topic:death wobble in steering when i brake.
Next Topic:turbo'ing a 2T-GEU
Current Time: Sat Nov 21 01:19:53 UTC 2026
Total time taken to generate the page: 0.0045349597930908 seconds
