Toymods » Tech & Conversions » order
toy_seca
Northan Beaches
order Wed, 26 March 2003 23:52 Go to next message
Can someone tell me in what order i should take stuff out of my gze halfcut. Ive taken most of the dash appart and the radiator off and all the pannels off what should i do next
1jdave
Re: order Thu, 27 March 2003 21:34 Go to previous messageGo to next message
the only things i can suggest are disconnect ecu and remove (keep inside house) feed wiring from ecu thru firewall disconnect only tthe things necessary to lift body off motor the more items youleave on front cut the easy it will be later. if you have struts, brakes/discs,steering rack leave these on eng assembly if possible simply lift body off eng. do exactly the same to refit. brake pads and flexible brake hoses should be changed. there will be items then that arent the same to change from one body to another. this is just an idea i havent seen one of these before but this is how i attacked mine. only other thoughts are before fitting engine check for wiring differences in cab and change over youll need wiring diagrams
Bugman
Re: order Fri, 28 March 2003 05:20 Go to previous messageGo to next message
hmmm.. what should I remove first.. get stuck in and pull everything your not using off Smiley =
toy_seca
Northan Beaches
Re: order Fri, 28 March 2003 05:34 Go to previous message
thanks for the help again guys Rolling Eyes
Previous Topic:20V teething problems
Next Topic:Good new turbo to replace CT26 on 3SGTE
Current Time: Sun Nov 1 11:49:29 UTC 2026
Total time taken to generate the page: 0.003741979598999 seconds
