Toymods » Tech & Conversions » Crackling noise out of exhaust
stradlater
Arthurs Creek, Victoria
Crackling noise out of exhaust Mon, 17 June 2002 10:27 Go to next message
I've got a bit of an exhaust on the peugeot, and when I downgear, it crackles. Which I like. I'm curious as to what the noise is, and how I can get a turbo (Ie mine) to work the same way, I just love the noise.
M.W.P.
Rocky Mountains, Canada
Re: Crackling noise out of exhaust Mon, 17 June 2002 10:49 Go to previous messageGo to next message
The crackle is probably caused by unused fuel exploding in the exst manifold. Most of the time its caused by vaccuum leaks on the inlet manifold or carb. Although some poeple have said that the change from leaded to LRP has caused it.
So... to get it to happen on a turbo, youll need to explode some fuel in the exst manifold or in the exst tubing.
Pumping large amounts of fuel into the engine during idle (off-throttle) could make it happen, but itll probably damage your turbo in time.
The way the rally guys do it is quite cool. Turbo anti-lag.
They pump excessive fuel into the engine during idle, and then on opening of the exst valves, they spark that cyls spark plug again causing the unburnt fuel to burn as it leaves the engine. The extra explosion then keeps the turbo spinning during gear shifts.
This is what causes the crackling on thier cars.
To do this though requires quite a cool ECU system.
I think this also shortens the lifespan of the turbo.
stradlater
Re: Crackling noise out of exhaust Mon, 17 June 2002 10:59 Go to previous messageGo to next message
I figured it was just unburnt fuel and doing it the way that the rally guys do, shortens the shit out of the life of the turbo.
I didn't think that it was going to be possible to make a turbo car do it, just given the way the car works and all.
oh well, it was a nice thought.
now to make the bmw do it.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Crackling noise out of exhaust Mon, 17 June 2002 11:22 Go to previous messageGo to next message
I had this happen to me on my old Scorpion before I sold it... I loved hearing it decelerate in 3rd and 2nd gears. At one stage it was running really rich on the carby setup I had, and it was flaming out the exhaust on 3rd gear compression/deceleration. Laughing
I asked one of the guys here in Ballina about it and he said it was to do with the different lobing on the camshaft (being small or 'torque' cam), and/or the timing setup. He actually re-curved the dizzy on it and tuned the Weber's I had installed, so that it didn't do it as severely, but still did it - I couldn't fix it properly for some reason (not that I really wanted to), but the flaming was fun... not real good for the fuel tank. Smiley $$
Re: Crackling noise out of exhaust Mon, 17 June 2002 12:43 Go to previous messageGo to next message
I've been a bit of a long time lover of this... My ke30 dirt road bashing/pizza delivering car has been through 3 mufflers cos of this, probly because of me turning off the key to make it happen Cool I've tried playing with mufflers to try and get the maximum amount of noise happening I can too, and I've suceeded in putting dents in the floor of my boot! Scares the absolute buggery out of other traffic too, they pull over and think their tyres are gone. Do it under a large concrete bridge, absolutely sensational.
My turbo ae86 also does it, cos of the harsh Haltech rev limiter that insists on backfiring. When it backfires through the intake, I'm NOT happy, but through the exhaust is fantastic, lets out quite decent looking flames...
So enjoy and encourage it! Retarded timing should help it, as will thrashing the thing and getting the exhaust really hot. I'm gonna try and study it Freak
`Cuda
windang
Re: Crackling noise out of exhaust Wed, 19 June 2002 07:29 Go to previous messageGo to next message
Hi my RA65 does it also just ask YOGI Smile
it's got a K&N filter so she also is also load on the breathin side and all gases are expeled through a 2 1/4 inch system leadin into a 3 inch cannon .had it tunned and even went 2 the trouble off buyin a air/fuel ratio gauge and all is sweet Wink
GOT 2 LOVE THAT DOWN SHIFT POP Smile
celicamad85
Banned member
Re: Crackling noise out of exhaust Wed, 19 June 2002 10:06 Go to previous messageGo to next message
steve i get that too in my ra65, my system is 4-2-1 extractors into one muffler only no catalytic convertor or resonator bullshit , 2.5 inch exhaust, uni filter fitted, mildly worked motor
i downshift constantly to pull up at lights, sve a bit of brakes probably use more fuel but you get lots of attention, i get more of an exploding cannon fire, like a machine gun
awesome
Pete
gold coast
Re: Crackling noise out of exhaust Wed, 19 June 2002 10:50 Go to previous messageGo to next message
If you want that noise on your turbo car, set your programable ECU to give it more fuel on overrun.
RA23_Sean
Western Sydney
Re: Crackling noise out of exhaust Wed, 19 June 2002 11:07 Go to previous messageGo to next message
That noise can also be caused by an exhaust leak coupled with unburnt fuel in the exhaust.
stradlater
Re: Crackling noise out of exhaust Fri, 21 June 2002 02:13 Go to previous messageGo to next message
Well, it sounds like something bad occuring in a turbo car, so I won't go to the effort of doing it.
:-_)
Celica_RA40
Re: Crackling noise out of exhaust Fri, 21 June 2002 07:35 Go to previous messageGo to next message
hey i have just started getting this crackling on my 18R-GEU celica i just put a straight through muffler on it off a racing 4 stroke dirtbike and it is cool sounds like a rally car.
Fattony
Re: Crackling noise out of exhaust Fri, 21 June 2002 08:47 Go to previous messageGo to next message
At least i know my car is operating properly then (ie. no crackles)
TOY77
Re: Crackling noise out of exhaust Fri, 21 June 2002 09:05 Go to previous messageGo to next message
G'day all,
My 18rg used to do this too. i was told that it was due to the straight through exhaust! sounded cool...
Now i make cool turbo sounds instead... Don't worry stradlater the 1g makes plenty of cool sounds to amuse yourself with!!!!!
Enjoy
Stew
yatesie
Re: Crackling noise out of exhaust Fri, 21 June 2002 09:44 Go to previous messageGo to next message
you guys are on the right track... it is due to unburnt fuel entering the exhust manifold, but its not all bad. THe sound is more prodominate in extracted cars, as most sounds are amplified. This un burnt fuel enters the manifold on over run because the carbi (im not so confident with EFi donks yet) is still pumping (allowing to pass)fuel, due to the engine having rev's up (and thus vacuum). The crackling can be altered by changin gthe overlap of your cam (being the reason why race/rally cars crackle REALLY loudly.. or have flames because they run enormous amouts of overlap)
Re: Crackling noise out of exhaust Fri, 21 June 2002 10:41 Go to previous messageGo to next message
As someone else said though, a lot of the newer/race cars will be doing it because of the anti-lag Smile
yatesie
Re: Crackling noise out of exhaust Fri, 21 June 2002 12:28 Go to previous messageGo to next message
sorry.... i cut myself of eariler... adding to my post.... crackling (or blatting as also know) isnt bad for your exust... as long as the carbie / EFi isnt pumping an inordinate amound fuel, producing flames out the back of a road car (i know we would all love to be shooting flames a la fast and furious), but yeah, its not good (espicially forr exhust O2 sensors). I think the whole of fast and furious is a load of crap, flames out of exhusts on full revs or load is bad (unless its a methanol or nitromethane drag car..... in that case more is best) I am sure that there is more in consistancies in that movie, my mate swears everythign that he sees in that movie is real..... so i just accept that he is a six pack short. Back to the topic.............. my car blats well, and i love it.... sounds wicked pulling up to lights, a real impression that you mean business.... and my car as a true sleeper (although not that quick, it beats VL NA's regularly) it has many scratches, and is at least a 4 tone paint job..... 2 tones of green, bog and primer... hehe Sleep
anyhow.. have a good one all
RA28
Re: Crackling noise out of exhaust Fri, 21 June 2002 13:07 Go to previous messageGo to next message
My car does it all the time. Whenever decelerating it goes snap-crackle-pop constantly. Just put a leak in the exhaust system. Mine is at the flange gasket (there is no gasket). Although this makes the carsound like shit when the foot is down (a pfft-pfft noise whenever one of the cylinders fires). Kinda sounds like a VW beetle. an old one.
Tim
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Crackling noise out of exhaust Fri, 21 June 2002 13:47 Go to previous message
Even a shitty old Scorpion that's barely been modified can blow off a N/A VL... but a tall gear range does help somewhat in that race. Smile
Previous Topic:Who makes custom engine mounts in Sydney?
Next Topic:4age bellhousing
Current Time: Sat Oct 31 16:23:44 UTC 2026
Total time taken to generate the page: 0.13355803489685 seconds
