Toymods » Tech & Conversions » Wiring Diagram 1g-gte
stradlater
Arthurs Creek, Victoria
Wiring Diagram 1g-gte Thu, 27 March 2003 10:23 Go to next message
I desperately need the wiring diagram and the directions as to how to wire the 1g alternator into the ra23 loom. Can ANYBODY help me out with this one please!~
sideshow
Re: Wiring Diagram 1g-gte Thu, 27 March 2003 10:46 Go to previous messageGo to next message
its not too hard
plug on back of alternator has 3 pins
the black/yellow goes to ignition
the yellow goes to alternator light in dash
the white goes to battery
the thick white goes to battery preferably thru 100 amp fusable link
stradlater
Re: Wiring Diagram 1g-gte Thu, 27 March 2003 11:13 Go to previous messageGo to next message
Thankyou, that does assist, however I need just a little more specific information.
"the black/yellow goes to ignition " When you say Ignition, you mean the ignition wire that goes live when the ignition is turned on, correct?
"the white goes to battery " When you say goes to battery, goes to which part of the battery, connects to the positive terminal, or the negative terminal?
That bit at the back is the voltage regulator, right?
Or do I still need to run the standard ra23 voltage reg?
sideshow
Re: Wiring Diagram 1g-gte Thu, 27 March 2003 11:33 Go to previous messageGo to next message
yer black/yellow goes to ign like when u get reds
thin white which is on 3 pin plug can be joint to the think white wire
the thick white wire which goes on the big bolt/nut on the back of alternater goes to the positive side of the battery
u dont need the original external regulator if its got one
but if it does have an external regulater then one of the wires on the plug for it would go back up to the dash for the warning light and one of the wires might even have 12 ignition
[Updated on: Thu, 27 March 2003 11:49]
stradlater
Re: Wiring Diagram 1g-gte Fri, 28 March 2003 09:44 Go to previous messageGo to next message
thanks heaps dude, but you need to be a little more specific. You say it goes to ignition when you get reds? what you mean get reds, get red lights on turning the ignition on?
and you say that the thin white wire goes to the battery positive terminal?
Now for external regulator, how do I know if the 1g alternator has an external regulator?
sideshow
Re: Wiring Diagram 1g-gte Fri, 28 March 2003 12:18 Go to previous messageGo to next message
the 1g alternater has an inbuilt reg
big black thing in back of alternater
its too new to have external reg anyway
reds i mean by oil light comes on power to coil
yer thin white goes to battery positive aswell its need to start the alternator charging by powering the exciter diodes
[Updated on: Fri, 28 March 2003 12:20]
Re: Wiring Diagram 1g-gte Fri, 28 March 2003 12:37 Go to previous message
Sorry to hijack, but are you able to do this sideshow? http://www.toymods.org.au/msgboard/index.php?t=msg &th=11709&start=0&rid=162&S=d3a18d 1a36f7bdbad5705f931465bb9b
Previous Topic:good tyres, not much road noise?
Next Topic:AW11 engine mount question
Current Time: Sat Oct 31 16:08:49 UTC 2026
Total time taken to generate the page: 0.12991213798523 seconds
