Toymods » Tech & Conversions » $@@@@ -=increasing boost=- @@@@#
_ELiTeHaYDeN_
$@@@@ -=increasing boost=- @@@@# Thu, 27 March 2003 15:41 Go to next message
On 3T-GTEU, stock ECU, CT20.
heres the situation, i wanna use a restricter valve to increase the boost from the stock 7psi, but i hear that restricter vavles get blocked easily(meaning unlimited boost) and bleed valves are useless, you get no low end boost, and the turbo works alot harder(cause of bleeding off).. any other ways to increase boost?
With fuel cut disconnected(in order to go over 7psi), and for example, a blocked restricter valve(endless boost).. i have no protecton? it'd just keep boosting till it blew up? or is there another form of protection?
clubagreenie
1st street on the right
Re: $@@@@ -=increasing boost=- @@@@# Thu, 27 March 2003 19:04 Go to previous message
http://www.toymods.org.au/msgboard/index.php?t=msg &th=11210&start=0&rid=1638&S=693a1 033e14d0ffd3a337bcae3042205
Try here
Previous Topic:Bellhousing alloy?
Next Topic:ma61 diff ratios
Current Time: Sat Nov 21 01:51:21 UTC 2026
Total time taken to generate the page: 0.0043599605560303 seconds
