Toymods » Tech & Conversions » how good are ct26
MR. 2
Parramatta
how good are ct26 Thu, 27 March 2003 21:32 Go to next message
I have a ct 26 high flowed to a t04e has the 54 compresser all the ceramic has been taken out, its all steel now...
i just wanted to know what the most effecent boost rating on this, im looking at 22psi i know it will boost to that but i dont know if it will be making good power with so much boost as the turbo is still pretty small.
i hope that i explained this well enough.
Danners
Central Coast, NSW
Re: how good are ct26 Thu, 27 March 2003 22:01 Go to previous messageGo to next message
I'm thinking of doing the same, where would i go to get mine hi-flowed?
Dan
ROBBO_ma61
Re: how good are ct26 Thu, 27 March 2003 23:45 Go to previous messageGo to next message
in stock form the ct26 is a bit inneficient (off ma70, mz21)The ct26 is the biggest stock turbo ever bought out on a car. but after it spools up it works quite well...can work them hard too...but the t04 rebuild is a great upgrade.
SUPRAGTE
North Sydney
Re: how good are ct26 Fri, 28 March 2003 01:15 Go to previous messageGo to next message
I've got the same hi-flowed ct26 on my supra at the moment.
It has the 54mm comp and 15 deg cut back on the exhaust turbine.
I haven't been able 10 run mine up to even 14psi yet cause the clutch just starts frying. It's putting out some serious ponies at 10psi. On 22psi it will be cranking out some big herbs! In the states they run them up to 28psi on 7mgte's. Any harder and your leaning on it too much.
On my website I've got compressor flow map for this exact turbo and if you look at it and understand compressor maps you'll see at 14psi its not even getting into the efficiency island so 22psi should put you right in there.
Is it a ct26 off a celica gt4 with twin entry or the higher flowing single entry? That will make a difference.
TA22-3SGTE
MACKAY
Re: how good are ct26 Fri, 28 March 2003 11:51 Go to previous messageGo to next message
I'm running a ST165 hiflowed single entry CT 26 with 50mm comp wheel on my 3SGTE and pumping out 260rwkw on 23psi , this turbo has quite often pumped out more than 30psi and have had no trouble .
Trevor
gabe
Re: how good are ct26 Sat, 29 March 2003 11:01 Go to previous messageGo to next message
sorry to hijack the thread but why is single entry better than twin entry?? is it purely because it flows better?
7M-Brisbane
Re: how good are ct26 Sat, 29 March 2003 12:15 Go to previous messageGo to next message
I haven't gotten around to hiflowing mine, but I have a friend making 216rwkw on about 16psi with his hiflow. He runs a 57mm compressor wheel - but this 16psi is nowhere near maxed out, he still has factory injectors so that's the retarding factor.
Another friend from memory has the 60mm comp wheel and he ran something like 26psi - ran 12.1 in Adelaide. Unsure what power figures he made.
I wouldn't run much more than 20psi on a 54mm hiflow, but again I haven't had one myself, so I'm really just basing this on what I've seen from friends cars. The only way to truly find out what your turbo can do reliably and efficiently is to have it done on a dyno.
Stenno
Re: how good are ct26 Sat, 29 March 2003 12:36 Go to previous messageGo to next message
7M-Brisbane wrote on Sat, 29 March 2003 23:15
He made around 250rwkw, through an auto box, he also ran 22psi to be precise, 57mm compressor I beleive Smile.
Specs of his car can be found @ http://www.turbosupras.com/pages/members/ntsemitsi dis.htm , although he's since fitted a GT40.
Re: how good are ct26 Sat, 29 March 2003 12:53 Go to previous messageGo to next message
Stenno, was that car featured on Autospeed at some stage or am I greatly mistaken? Wouldn't be the first time...... Very Happy
Stenno
Re: how good are ct26 Sat, 29 March 2003 12:56 Go to previous messageGo to next message
gianttomato wrote on Sat, 29 March 2003 23:53
A long, long time ago, in a galaxy Far far away Smile
Yup, that's the sucker Smile
Alot has changed since then tho......
SUPRAGTE
North Sydney
Re: how good are ct26 Sat, 29 March 2003 23:41 Go to previous messageGo to next message
That supra on that link!!!! Wow
Some mega dollars thrown into that one!! Close to $25K id say.
ma61_turbo
Re: how good are ct26 Sun, 30 March 2003 05:49 Go to previous messageGo to next message
SUPRAGTE wrote on Sun, 30 March 2003 09:11
More than that I think, not that I've ever asked him Wink
It is an impressive car I must admit. It truly does not sound like any other 7m-gte motor I have ever heard, almost seems to have a big-block sound to it. I think it's still awaiting a motec install, haven't seen him for a while though. Still waiting to be taken for a spin in it Evil or Very Mad
Dave
Fattony
Re: how good are ct26 Sun, 30 March 2003 07:54 Go to previous message
Hmmm looking at this thread my turbo is better that what i have been led to believe. How do u know what size wheel u got?
Previous Topic:Toyota Soarer (JZZ30) fuel economy question
Next Topic:tyre pressures
Current Time: Mon Nov 2 02:31:24 UTC 2026
Total time taken to generate the page: 0.0052869319915771 seconds
