Toymods » Tech & Conversions » Knock sensors.
_ELiTeHaYDeN_
Knock sensors. Fri, 28 March 2003 15:27 Go to next message
If you have a knock sensor, i thought that it should technically be impossible to hear any pinging because the knock computer will retard the timing well before it starts to get serious? wanna crank the boost on my 3t-gte, but worried about knock, will the knock computer take care of my worries? if i do plug it up alittle to high?
JDM hachi
was adelaide now newcastle
Re: Knock sensors. Sat, 29 March 2003 05:01 Go to previous messageGo to next message
from what i know about knock-sensors they take a few seconds to work(ie detect knock then wind back timing)so a certain level of knock can be heard (i wouldnt rely on this as a safety measure though) also are you sure that your knock sensor is working correctly, if its not working 100% i could see engine busting issues arising.
SUPRAGTE
North Sydney
Re: Knock sensors. Sat, 29 March 2003 09:03 Go to previous message
No they don't take a few seconds to work. They are very very fast at retarding the timing. They sample over 50 times a second to see if there is detonation.
Problem is, they are only used in closed loop control. When you are giving your throttle a wallaping the ecu is running in open loop and relies on pre-determined ignition values.
So the timing is running of fixed values, if you lean out, have a bad batch of fuel, etc etc it will still detonate.
Previous Topic:Bigger turbos
Next Topic:Fitting SC14 Supercharger - need some help
Current Time: Sun Nov 1 10:15:24 UTC 2026
Total time taken to generate the page: 0.0049560070037842 seconds
