Toymods » Tech & Conversions » sprinter vent control wont work??
blury
sunshine coast
sprinter vent control wont work?? Mon, 17 June 2002 12:30 Go to next message
My friend just a bought a stocko sprinter allthough being a good buy theres one problem the vent control on the dash wont work its always stuck on the demister no matter what you move it too??? does anyone have any idea how to fix this?
shane
Wollongong
Re: sprinter vent control wont work?? Mon, 17 June 2002 12:38 Go to previous messageGo to next message
I have never owned a sprinter but from what I have seen you will probable have to pull some bits apart so you can have a look at the machanical side of the switch. It is probable a broken hing or the pull cable has sliped out of it's anchor point, you should be able to figure it out by moving the switch around and examining how it works. Rolling
IRA11Y
Club Member
Re: sprinter vent control wont work?? Mon, 17 June 2002 22:16 Go to previous messageGo to next message
Is there any tension on the armature when you try to move to a different setting? if not then the cable is either broken or disconnected. if you still feel the cable moving then it is likely that the plastic arm that connects to the flap has broken and the unit may as well be thrown away....not such a big deal though because all AE80 series rollas ran the same nippondenso fan unit and theyre fairly cheap from a wrecker.
rwdTrueno
Auckland, New Zealand
Re: sprinter vent control wont work?? Tue, 18 June 2002 02:47 Go to previous messageGo to next message
damn, reminds me I should clean my heater out sometime. it spits dirt bits and stuff whenever I vent it into the cabin Smile
gearb0x
Re: sprinter vent control wont work?? Wed, 19 June 2002 02:10 Go to previous message
i had the same problem the same problem in the T-18
it turned out the plastic thingo the cable attaches to was broken, i had to pull all the dash out, and the heater..
Pulled the heater apart and replace the drum thing it attaches to from spare T-18... works like a charm now
Previous Topic:GZE troubles. AW11 People PLEASE help
Next Topic:cost of an 18r-g conversion
Current Time: Sat Nov 21 19:29:24 UTC 2026
Total time taken to generate the page: 0.007317066192627 seconds
