Toymods » Tech & Conversions » Head problems?
M.W.P.
Rocky Mountains, Canada
Head problems? Mon, 17 June 2002 13:02 Go to next message
Ok... first, sorry, this doesnt have anything to do with Toyotas, but i couldnt think of a better place to ask about this problem.
This is the head off a Lancia 2L (a friends car im helping with).
About 5000kms ago, it was rebuilt after blowing the head-gasket.
Im not exactly sure what was done in the rebuild.
Now its running as if the head-gasket has been blown again... not really rough, but enough to take it off the road.
These pics are of the head, the second it came out of the engine bay. It hasnt been wiped down at all or cleaned in any way. The wet oil on the head is there because we pumped some into the cyls before removing the head, as it hasnt been run in a long time.
Now... im writing all this because i want to ask of your opinions on the condition of the head in these photos.
I guess the main question is, does it look like it had a rebuild 5000kms ago?
Note the layers of carbon on the valves, and the green/white crud in the coolant runs.
http://www.overclockers.com.au/~mwp/temp/lancia/MVC-003F.JPG
The other pics are:
http://www.overclockers.com.au/~mwp/temp/lancia/MV C-006F.JPG
http://www.overclockers.com.au/~mwp/temp/lancia/MV C-007F.JPG
Thanks.
[Updated on: Mon, 17 June 2002 13:04]
Celica_RA40
Re: Head problems? Mon, 17 June 2002 13:11 Go to previous messageGo to next message
i have a feeling that if it was rebuilt whoever did it did a shit house job as i think that the calcium buildup(or thats what it looks like) wouldnt happen in 5000 ks. sounds like the head or block hae warps in them. so have them decked then it shouldnt blow any more gaskets.
M.W.P.
Re: Head problems? Mon, 17 June 2002 13:18 Go to previous messageGo to next message
Sorry... forgot to mention that the current head-gasket does look perfect. Its on the head in those pics.
It was burning oil, so im thinking it has to be either rings and/or valve stem seals. The coolant that came outa the engine was perfectly clean... havnt looked at the oil.
Also... i could move the pistons in the block quite easily side-to-side with my hand. Didnt measue how far. Sound bad?
[Updated on: Mon, 17 June 2002 14:08]
MS-75
Re: Head problems? Tue, 18 June 2002 05:11 Go to previous messageGo to next message
As for the oil burning, did it have a lot of blowby? Sometimes a lot of oil burning can be attributable to a broken compression ring-which in turn can cause damage to the oil ring-causing some smoke. To eliminate this possibility-once it is reassembled do a compression test on each cylinder
Another way the oil can get in is via the stem seals (as you said) A good way to check is to have a look at the valve shafts through the intake/exhaust ports. If the shaft of the valve looks all oily and the back of the valve has a carbon built up on it-looking like it has run down the shaft of the valve, then the stem seals are shot.
As for the movement of the pistons-a description like that is indicative of one of three things generally
1. The pistons installed were too small for the bore-ie 10 thou oversize pistons in a 20 thou over bore. (not all that likely-its a pretty big screwup)
2. The pistons and bore are totally flogged out and need attention.
3. The motor has been fitted with big clearance race style forged pistons (ie my Venolias could be wiggled an alarming amount in the bore.) The big clearance is generally because a high silicon content material with a big thermal expansion property has been used.
Have a look at the markings on the piston crowns and ask a lanci/alfa workshop what type of slugs they are and what the clearance is supposed to be.
Have the radiator checked as well-having it opened up and cleaned out at the local radiator shop is cheap insurance.
It could be a head gasket-but if the gasket looks okay between the flamerings in the gasket and the cooling passages, then it probably is okay. It could be a hole in the head somewhere, so have it checked for porosity (when you have it skimmed) Also have the head flushed out.
I'd recommend the following
Keep the gasket you have-don't but a new one yet-you cant re-use them reliably-but it'll be fine to reassemble the motor and diagnose with-just clean the head and block up carefully with a razor blade and scotchbrite pads. Next get a big metal ruler or similar and check the head for flatness. (lay the edge across the head in a few directions-if it rocks at all-have the head skimmed-do the same for the block). Get a can of Hylomar or similar head gasket adhesive spray and put the head back on (change the stem seals while you're at it) Do a compression test, then see if it still behaves wierd.
If you've go any Q's about what I've said just post again-No question is too basic to ask-don't be shy.
Sean
M.W.P.
Re: Head problems? Tue, 18 June 2002 05:58 Go to previous message
Thanks for all that info... a great help.
I know most of the basics for all this stuff, just havnt done it before so its a little hard to know what to look for.
We also only spend a few hrs on it each week, so its slow going.
Previous Topic:diff seats in sprinter...
Next Topic:Cams in a 103Kw 3S-GE
Current Time: Sat Oct 24 21:21:09 UTC 2026
Total time taken to generate the page: 0.015454053878784 seconds
