Toymods » Tech & Conversions » ta22 w58 conversion
purpleminiep
Mentone
ta22 w58 conversion Sun, 30 March 2003 07:13 Go to next message
We are putting a w58 gearbox into a 3t equiped w58. We have a auto tailshaft and crossmember. Does the auto crossmember fit without too much modifying. What have people used before?
Brad
ChuckLandwehr
Re: ta22 w58 conversion Mon, 31 March 2003 11:48 Go to previous message
Two pieces of 10mm steel plate 50mm wide by about 250- 280mm long suitably drilled with holes to bolt to manual TA22 gb x member. I actually had to weld a threaded stud into the plate, because the box sits in an awkward position, which prevents using 2 nuts and bolts each side, to hold x member to plates.
If you want precise dimensions, your'e in luck! I will measure the assembly Tusday! PM me to jolt the memory, because somtimes I dont visit tech forum for a bit.
Regards Chuck.
Previous Topic:Where 2 find a sprintex s-charger kit
Next Topic:JP spec 5M-GE --> RA65
Current Time: Tue Oct 27 07:56:33 UTC 2026
Total time taken to generate the page: 0.0069239139556885 seconds
