Toymods » Tech & Conversions » 1ggte Guys look in Pics required
CrAiGzEE
south of the big smoke
1ggte Guys look in Pics required Mon, 31 March 2003 01:11 Go to next message
guys im thinking of relocating my cooler has anyone got pics of there setup ?
Nark and dave i also wouldnt mind looking into water to air setup can ya give me an idea whats involved and what $$$ im looking at
Craig
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1ggte Guys look in Pics required Mon, 31 March 2003 01:32 Go to previous messageGo to next message
Mine is a standard 1G item, so I can't really help you there, unless you want to track one down and install it.
Autospeed did a test on the flow of various intercoolers, and the w/a one off the 1G scored pretty well. Flowed better than the a/a one from what I remember.
The good thing with a w/a setup is that there's bugger all piping, so less lag. Check out how far the air has to travel in my setup.
http://www.toymods.org.au/Nark_Gallery/.thumb_Engine.JPG
celicaboy
Re: 1ggte Guys look in Pics required Sat, 26 April 2003 07:47 Go to previous message
you can try avo... they make a w/a kit in the rav4 turbo kits and tghey are a pretty good set up... very small piping involved and they are very efficient...
but if you wanna make your own you need to get a cooler to suit then weld plates on it where the water can be stored... you godda get a pump of some sort.. i hear they use boat bilge pumps then they feed the air to a oil cooler to the front then feeds into the intercooler and it cycles around like that.. i am not sure if they use water from the engine or they have seperate reservewire but that is meant to be a very good set up.. they tested that setup on wrx's and it showed to be around 30% more efficient in cooling then a 1ggte size a/a cooler
Previous Topic:AE86 + 4AGZE = $$$?
Next Topic:205/55/R15 on Ae82 Rolla??
Current Time: Thu Oct 29 02:49:19 UTC 2026
Total time taken to generate the page: 0.0050210952758789 seconds
