Toymods » Tech & Conversions » sprinter head light globes!
Ae86-Te
Tas, Australia
sprinter head light globes! Mon, 31 March 2003 10:23 Go to next message
hey, got a 83 sprinter and I have no service manual, so I was wondering, what sort and size(watts) ,headlight globes that will suit?? I want to be big'n'bright and clear!!Shocked
thanx
Youngy
Eskilstuna, Sweden
Re: sprinter head light globes! Mon, 31 March 2003 12:58 Go to previous messageGo to next message
I have 85/100s in mine. Makes things nice and bright on high beam. Just pull out theold globe and take it with you for a match at any car parts place!
Re: sprinter head light globes! Mon, 31 March 2003 13:36 Go to previous messageGo to next message
Standard ones are 60/55w - you can increase this slightly, but if you want to go too far I'd suggest an extra set of relays right next to the lights - it's amazing the difference this can make.
shinybluesteel
melbourne
Re: sprinter head light globes! Tue, 01 April 2003 07:49 Go to previous messageGo to next message
they take H4 type globes, i recently replaced mine with "superwhite" type globes, they cost me 40 bucks, but i didn't want to by autotechnica dodgy ones (might have been ok)
to get them out, there is a wire clip that holds them in, pull the rubber cover off first and look for the loop on the end of the bit of wire. this kinda fits behind a hook, you can work out how it all works once you pull the globe out (i worked it out on a headlight i pulled out of my parts car)
i was going to run higher wattage ones, but was a little paranoid about meting the headlight housing, as they aren't the easiest things to get. the "white" bulbs definately look better though, might have to try the relay trick.
Ae86-Te
Tas, Australia
Re: sprinter head light globes! Tue, 01 April 2003 08:48 Go to previous messageGo to next message
thankyou guys, just another thing.. whats the go with that relay trick?
shinybluesteel
melbourne
Re: sprinter head light globes! Tue, 01 April 2003 10:34 Go to previous message
id say it is putting another relay/relays closer to the headlights, with phat cable going from the battery to the relay to the headlights, cuts sown on resistance in the wires, hence more current goes through the filaments in the bulbs.
i want high intensity discharge lights, i told a friend of mine this, and he said "that sounds fking dicgusting"
Previous Topic:body kit for TA23
Next Topic:supergharger problems
Current Time: Thu Nov 19 08:06:37 UTC 2026
Total time taken to generate the page: 0.050784111022949 seconds
