Classifieds » Miscellaneous » 3SGE Gen 1 and RWD gearbox to suit.
crazyracer
3SGE Gen 1 and RWD gearbox to suit. Mon, 31 March 2003 12:31 Go to next message
For Sale
Jap spec Gen 1 3SGE.
Has been used in RWD conversion, so has 2S RWD sump.
Also has adjustable cam sprockets and twin Weber manifold/adaptor plate.
I believe this motor has only done about 15,000km and is in vgc.
$500 ono.
Photos...
Also have available to suit T50 gearbox with 1S bellhousing to suit converting the above motor to RWD.
$180 ono
0412 148 773
in Melbourne
Attachment: 3sge_gen1_1.jpg
(Size: 45.95KB, Downloaded 26 time(s))
Attachment: 3sge_gen1_2.jpg
(Size: 51.74KB, Downloaded 24 time(s))
[Updated on: Wed, 02 April 2003 09:45]
Pumpkin
Toymods Board Member
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 01:00 Go to previous messageGo to next message
Why do you have to be in Melbourne!!! I would have had it !!!
Joshstix
Toymods Vice President
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 03:36 Go to previous messageGo to next message
You are going to Melbourne for a holiday in about a month or so remember. Maybe it will still be available and some generous person will bring a car that can carry and engine along on your holiday.
Shteeve
near chris and murray vic
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 04:50 Go to previous messageGo to next message
can i just ask what car it came out of??
EMP-2TG
Carlingford, Sydney
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 08:04 Go to previous messageGo to next message
damn i want it Sad
crazyracer
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 08:19 Go to previous messageGo to next message
I think the motor was in a TA22 Celica.
I was going to put it in a KE70, but ended up going with a Gen 2 3SGE and W57 supra box instead (oh and it ended up in a Datsun 1600 as well)
EMP-2TG
Carlingford, Sydney
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 08:23 Go to previous messageGo to next message
what kind of work would you need to do to drop it into a ke30?
crazyracer
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 13:30 Go to previous messageGo to next message
Main issues are...
1. making some engine mount (pretty easy if you can use a welder)
2. plumbing the cooling as the water outlet from the head is at the back. I just got some alloy tube and ran it down the side of the motor.
3. Distributor. This is also at the back and can cause some clearance issues. There are a number of ways which you can deal with this depending on whether you are going to run carbs, after market efi or the original induction.
4. Need to get exhaust manifold made. I do have a RWD exhaust manifold for it which may or may not suit the car you want to put it in.
Otherwise there is a clutch and flywheel to go with it to suit the T50, it requires a hydraulic system though. Spigot bearing is already in place.
Simon
EMP-2TG
Carlingford, Sydney
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 22:31 Go to previous messageGo to next message
cool thanks man Smile
TRD78
Re: 3SGE Gen 1 and RWD gearbox to suit. Tue, 01 April 2003 22:44 Go to previous messageGo to next message
So since it came out of a TA22 would it be a straight bolt up to another one or was ur TA22 heavily modified to fit it?
crazyracer
Re: 3SGE Gen 1 and RWD gearbox to suit. Wed, 02 April 2003 09:34 Go to previous messageGo to next message
I think the exhaust manifold I have for it was for the TA22, so that shouldn't be a problem.
It was using the weber manifold, so if you have a pair of 40 DCOEs or some dellorto or solexes you could use those for carburation.
The only issues will be the engine mounts (I have some that may work), plumbing the cooling system which isn't a biggie and the Distributor.
I've used the cut down dizzy from it in my other motor as a sync trigger. You'll need to find another one to modify to your needs. I have seen a 3SGE done with a dizzy mounted to the front of one of the camshafts, which solves the rear clearance issue.
[Updated on: Wed, 02 April 2003 09:35]
crazyracer
Re: 3SGE Gen 1 and RWD gearbox to suit. Wed, 02 April 2003 09:48 Go to previous message
I've added some photos to the original message.
In it you can see the exhaust manifold which I think was for the TA22, and the weber manifold with a single Weber bolted to it (although the manifold is for twin side drafts)
Previous Topic:Bike for sale....
Next Topic:ct26 high flow
Current Time: Sat Oct 31 08:03:43 UTC 2026
Total time taken to generate the page: 0.10415005683899 seconds
