Toymods » Tech & Conversions » Rims not fitting.
4AGE
Rims not fitting. Tue, 01 April 2003 07:13 Go to next message
Hey guys. Just wondering... With VACC regulations and such. I have a set of 15 inch rims that don't fit on my car. I know its illegal to put in spacers. What options do i have to whack these in. At the moment the problem is that i don't want to go under 195/50 as a front tyre. And the front tyres rub on my strutts. After a 5mm spacer and nuts are screwed in 3 turns.
I have come to the conclusion of these 2 options.
1) Putting landcruiser studs in my hub which give me that extra 1cm or so. and putting 7mm spacers and wallah??? Illegal? Trouble changing my tyres? Trouble with Cops? Trouble elsewhere?
2) A place near my joint mentioned hub extentions. Does any of you guys know what they are??/ Where they can be done? Or how much they should cost? Pros? Cons? such as handling and/or reverting back to my original stud setup.
3) Open to all options.
Pleaseeee HELP!
If anyone does recon its not worth for these set of rims.. I'll post pictures of the rims in 48 hours.
4AGE
Re: Rims not fitting. Tue, 01 April 2003 12:56 Go to previous messageGo to next message
help please?
4AGE
Re: Rims not fitting. Tue, 01 April 2003 23:16 Go to previous messageGo to next message
Hmmm either u guys are just waiting for the pics or there is virtually nothing that can be done.
haggis
Re: Rims not fitting. Tue, 01 April 2003 23:24 Go to previous message
Spacers are a "Bad Idea"(tm) in almost every situation. If you bought the rims from a store, then you should take them back and get the correct ones for your car. If you bought them second hand....
The best (and only really safe way) to fix this sort of problem is get the rims with the correct offset.
Plenty of people use spacers, but more important than them being illigal, they arnt the safest way to fix the problem. Many a wheel stud has broken because of bad use of spacers.
Craig.
Previous Topic:2tgeu wiring
Next Topic:1g-gte oil filter and oil
Current Time: Thu Nov 19 14:00:26 UTC 2026
Total time taken to generate the page: 0.0055890083312988 seconds
