Toymods » Tech & Conversions » Priming Oil Pump (T series engine)
inferno
icon5.gif  Priming Oil Pump (T series engine) Tue, 01 April 2003 10:13 Go to next message
Does a 3TGTEU oil pump need priming after dismantling it? is it just a matter of filling it with oil and putting it in? and how far should the oil relief screw on the side of the pump be screwed in? wish this was covered in the manual.
cheers.
ChuckLandwehr
Re: Priming Oil Pump (T series engine) Tue, 01 April 2003 12:27 Go to previous messageGo to next message
The relief valve spring cover, should be tightened fully, fill the pump with oil when assembling. Before fitting the oil pump spiral gear drive, located on the side of the block, use a broad blade screwdriver to rotate the oil pump(2-3 litres of oil in sump), and listen to all the air being pushed out as the oil fills your crankshaft,camshaft etc. probably 20 to 30 turns of the pump. When the engine is installed in the car, remove spark plugs, and crank the engine over for 30-60 seconds on the starter, this will ensure that you do not "dry start" the engine.
Good luck with the rebuild.
Regards Chuck
inferno
Re: Priming Oil Pump (T series engine) Wed, 02 April 2003 05:00 Go to previous message
great thanks chunk!! not sure how i'll go turning the oil pump over using the screwdriver method as i can't get the oil pump drive shaft out without taking the head off (it hits the head, just under the distributer).
Previous Topic:SR20DET mods any ideas people
Next Topic:Over-reving when downshifting.
Current Time: Tue Nov 24 12:01:54 UTC 2026
Total time taken to generate the page: 0.0072848796844482 seconds
