Toymods » Tech & Conversions » Airbox Modification with pic
BlackSupra
Airbox Modification with pic Tue, 01 April 2003 10:53 Go to next message
I was talking to people some time back about cold air intakes and air box modifications so i thought i would share this little mod.
MA61 Supra airbox meets the angle grinder. Im running a K&N stock size filter in this modded box (which has a larger filter area than a pod) and the box is surrounded by a heat shield, which seals against the bonnet. Also running a 4 inch cold air intake to front bar.
Pic at www.geocities.com/ifli4u/airbox.jpg
Lost a bit of low end torque esp in 3rd gear, however the top end gains were pretty noticeable!
The cost, well the filter was $130, heat sheild material $7 from clark rubber and the use of a 4 inch angle grinder. About $20 if u need to hire one.
Just thought id post this if anyone was interested
[Updated on: Tue, 01 April 2003 10:55]
SupraPete
Re: Airbox Modification with pic Tue, 01 April 2003 11:53 Go to previous messageGo to next message
I'm into these airbox mods. I want to do one that surrounds my pod filter.
The lexus site does a good one, step by step.
http://www.users.bigpond.com/pgscott/BFIDIY/BFIDIY .html
BlackSupra
Re: Airbox Modification with pic Tue, 01 April 2003 12:41 Go to previous messageGo to next message
Yeah that looks the goods, id say that mine is probably 90% sealed, but if i could seal the box it would work better of course Very Happy
But this mod cost $7 dollars considering i already had the pipe, angle grinder and filter, by this stage.
If i do go ahead with the planned conversion ill be making a custom airbox 100% sealed with a pod, best of both worlds.
Until then this will work fine because this airbox design is a prick to work with!
[Updated on: Tue, 01 April 2003 12:41]
Apollo
Brisbane, QLD, Australia
Re: Airbox Modification with pic Tue, 01 April 2003 13:22 Go to previous messageGo to next message
I can only sort of picture what you have done, but, where you have the seal around the bonnet, would it be feasible to stick some insulation on the bonnet that covers the area above the filter?
Bonnets get hot of course, and it might help. Just an idea.
BlackSupra
Re: Airbox Modification with pic Tue, 01 April 2003 13:45 Go to previous messageGo to next message
Yes its a good idea, but i dont want to seal it in like that, too hard to access.
i wish i had a pic of the one on my old car, made it outof aluminium and glued the thing in, with a foam strip to seal against the bonnet, 02 rush pod filter fed by a 4 inch cold air intake, the whole thing was sealed!
In winter the thing sounded like a jet turbine winding out!! It made a massive difference!!!
This was all in an effort to prevent buying a pod filter!
The new engine will get a pod though and a sealed box Smile
Apollo
Re: Airbox Modification with pic Thu, 03 April 2003 23:34 Go to previous messageGo to next message
BlackSupra wrote on Tue, 01 April 2003 23:45
No, I mean stick insulation on the underside of the bonnet in the area above the air filter.
So when you lift bonnet, the insulation goes up with it because it's stuck to the bonnet. Wink
BlackSupra
Re: Airbox Modification with pic Thu, 03 April 2003 23:43 Go to previous message
ahhhhhhhh!
your an ideas man! Very Happy
Previous Topic:Wiring : How does this sound?
Next Topic:Motor for my KE30
Current Time: Wed Nov 18 20:11:34 UTC 2026
Total time taken to generate the page: 0.0060410499572754 seconds
