Toymods » Tech & Conversions » where is the 1jz crank angle sensor?!
where is the 1jz crank angle sensor?! Tue, 01 April 2003 11:06 Go to next message
Paul and I had a look over the engine, but it didn't seem to leap out at us. Admittedly, it was dark and we were using a torch, but can anyone shed some light on this?
ChuckLandwehr
Re: where is the 1jz crank angle sensor?! Tue, 01 April 2003 12:15 Go to previous messageGo to next message
I am lead to believe that the 1JZGTE engine uses 2 cam angle sensors, and 1 Crank angle sensor which is located at the extreme front RH side of the engine. If anyone can comment please do so.
Regards Chuck.
Re: where is the 1jz crank angle sensor?! Tue, 01 April 2003 12:26 Go to previous messageGo to next message
The crank angle sensor on my VVTi 2JZGE is way down low on the RHS at the front of the engine. You should see some wires leading down to it. There is also a cam angle sensor which is on the head, on the left side towards the back. I'd imagine the 1JZGTE would be the same.
Re: where is the 1jz crank angle sensor?! Wed, 02 April 2003 05:36 Go to previous messageGo to next message
any more help? please?
with the number of 1jz owners out tehre, I'd have thought a few more people could point to these important items Razz
also the position of the 2 (?) cam sensors would be good.
I'm assuming the crank angle sensor is in the same place as for the 2jz, but the heads are quite different, so cam andle might not be?
GT... is that near the water temp sensor?
Re: where is the 1jz crank angle sensor?! Wed, 02 April 2003 06:13 Go to previous message
Draven, the crank angle sensor is way down low on the RHS. It is tucked in behind the crank pulley and the cam belt tensioner. What is visible of it looks like this:
http://members.optusnet.com.au/gianttomato/Toyota%20Power%20/Crank%20angle%20sensor.jpg
If you were to undo the bolt and pull it out, all you'd see is a small silver cylinder a couple of centimetres in length.
The cam angle sensor(s ?) simply has to be in the head. My 2JZ only has one. It looks like this:
http://members.optusnet.com.au/gianttomato/Toyota%20Power%20/cam%20angle%20sensor.jpg
The cam angle sensor is between the 5th and 6th injector on the intake cam side of the head on the outer side.
Sorry about the shitty photos and writing. I hope this helps.
Previous Topic:need some help getting Vacuum diagram for gen3 3SGE
Next Topic:2TG vacuum solenoid valve?
Current Time: Tue Oct 27 11:38:56 UTC 2026
Total time taken to generate the page: 0.0049839019775391 seconds
