Toymods » Tech & Conversions » Twin T/B on 4AGE
rollaboy
Coffs
icon3.gif  Twin T/B on 4AGE Tue, 01 April 2003 12:33 Go to next message
Has anyone ever thought about having twin throttle bodies on a 4age? Like you could cut one end off and get another T/B welded on and wire it some how.
Would there be any advantage??
Wouldn't having more air coming into the peluim be better then a single T/B??
I have seen this on a crappy charade and was just wondering how it would go on a 4age.
Any ideas??
Re: Twin T/B on 4AGE Tue, 01 April 2003 14:10 Go to previous messageGo to next message
Most people opt for quad throttles when they reach the limitations of the factory single throttle. Note that you'd need some fairly serious mods before the throttle became a significant restriction.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Twin T/B on 4AGE Tue, 01 April 2003 17:34 Go to previous messageGo to next message
One of the magazines (I think Zoom) had a twin throttle body intake plenum made up for an excel, but not because the standard one was a restriction. The twin throttles were used to balance uneven airflow to different cylinders. The cylinder closest to the TB gots less air as most of it was rushing past it, hitting the back of the plenum & giving the furthest cylinder plenty of air.
Now this was with a cheapass mass production car that wuld have had a matching induction system, I imagine the 4AGE would have a fairly better design.
It would be interesting to have it tested though.
rollaboy
Coffs
Re: Twin T/B on 4AGE Wed, 02 April 2003 13:31 Go to previous messageGo to next message
Thanks for the replys.
Would you wire a extra TPS up to the original one and have a setup for the throttle cable??
rollaboy
Coffs
Re: Twin T/B on 4AGE Sat, 05 April 2003 02:10 Go to previous messageGo to next message
Anyone???
Would you need a After Market ECU??
[Updated on: Sat, 05 April 2003 02:14]
BigWorm
Turramurra, Sydney.
Re: Twin T/B on 4AGE Sat, 05 April 2003 02:14 Go to previous messageGo to next message
You wouldn't use a 2nd TPS, but you would need to link it to the 1st throttle actuator.
Have a look at the cam/actuator that the cable goes too, there will probably be a second slotted cam for another cable to run off it, you'd just have a cable going from this to the new T/B.
shinybluesteel
melbourne
Re: Twin T/B on 4AGE Sat, 05 April 2003 11:10 Go to previous messageGo to next message
id say it would be a lot easier to use one big TB than grafting on another.
as others have said, "if you were making enough power to need this mod", you would already have aftermarket management, so that would be no problem.
if you wanted to do something like this, the first thing to do would be throw away the stock inlet manifold.
if i ever get around to getting a 4age, i will be making a group A vn commodore style inlet manifold, only with one TB and only 4 trumpets,
maybeye something involving slide throttles.
grim boy
Re: Twin T/B on 4AGE Sun, 06 April 2003 12:01 Go to previous messageGo to next message
actly the reasion for twin or quad t/b is better throttal responce more than flowing more air
dennis
rollaboy
Coffs
Re: Twin T/B on 4AGE Sun, 06 April 2003 12:05 Go to previous message
Yeah well i was just trying to come up with some thing different that hasn't been done before.
Previous Topic:engine mounts in Crown 1UZ-FE
Next Topic:Steel wheels to suit toyota RWD?
Current Time: Wed Nov 18 22:12:27 UTC 2026
Total time taken to generate the page: 0.015688180923462 seconds
