Toymods » Tech & Conversions » GZE supercharge engange
ae86slaver
GZE supercharge engange Wed, 02 April 2003 05:37 Go to next message
Since finding out that the previous owner of my car had 'hard-wired' my superchager on, i have discovered that this may well damage it in the long run. How can i remedy a switch to disengage/engage it, and can somebody explain the 'magnetic' clutch out and what it does? I can't seem to hear mine tick!
JDM hachi
was adelaide now newcastle
Re: GZE supercharge engange Wed, 02 April 2003 06:27 Go to previous messageGo to next message
have a look at a wiring diagram for the 4agze, the computer has a terminal used to switch a relay which engages the magnetic clutch, if you re wire this part of the loom then your s/c should work as per factory.the magnetic clutch is exactly that a clutch which is operated electro-magnetically (ie when power is applied then the clutch will engage- turning the s/c or a/c)
Ribbo
Northern Beaches
Re: GZE supercharge engange Wed, 02 April 2003 09:16 Go to previous messageGo to next message
are you running the stock ecu?
if not, it might be always on because your aftermarket one isn't able to turn it on and off....
the problem id face if using my microtech digi 1
sideshow
Re: GZE supercharge engange Wed, 02 April 2003 10:53 Go to previous message
theres a pin called smc
which is called supercharger magnetic clutch
it earth triggers the superchager relay which then earths out the earth side of the supercharger magnetic clutch
the supercharger has ignition to it aswell
Previous Topic:ST205 GT4 brakes
Next Topic:1jzgte turbo setup
Current Time: Wed Nov 18 21:04:00 UTC 2026
Total time taken to generate the page: 0.0064318180084229 seconds
