Toymods » Tech & Conversions » clutch problem
Bigfrek6
Maitland, NSW
clutch problem Wed, 02 April 2003 07:03 Go to next message
I change the clutch pump (where you put the fluid in) yesterday and changed the line, but for some reason i cant get fluid into the system, it just seems to sit in the fluid container and not enter the lines.
Everything works because when i open the bleed valve and press the pedal, air comes out, but when i try to bleed it properly it just doesnt work.
Am i missing something here, is there a 1-way valve or something that may be clogged.
Steve
knackers
berala sydney
Re: clutch problem Thu, 03 April 2003 10:02 Go to previous message
sound like you got a blockage in the line
take the line back out and blow it out with the compressor
replace and bleed it should fix the prob
cya knackers
Previous Topic:1GGTE timing belt
Next Topic:Mines ECU
Current Time: Wed Nov 18 05:31:30 UTC 2026
Total time taken to generate the page: 0.0040731430053711 seconds
