Toymods » Tech & Conversions » electronic speedo on 20v???
bexi
electronic speedo on 20v??? Wed, 02 April 2003 13:15 Go to next message
hey guys
i'm looking at getting a 20V in a corrolla that i've found for sale
dont know much about these motors and was wondering how you get the electronic speedo to work with an analogue speedo... is it just a matter of fitting a drive gear instead of the electronic pick up or what???
thanx
bexi
EvilJack
Sutho/Hills NSW
Re: electronic speedo on 20v??? Wed, 02 April 2003 13:24 Go to previous messageGo to next message
i htink you can get an adapater made up from any auto elec.
sideshow
Re: electronic speedo on 20v??? Wed, 02 April 2003 14:13 Go to previous messageGo to next message
wehat do u mean
if the speedo is electronic and not cable all u need is the electronic speedo drive that comes factory in most 20v gboxs and run the signal wire to the electronic speedo
i dont quite understand what u wanna do
which speedo u using
if u run yr factory analoge one then just swap the speedo drive from yr orig box to the 20v box
tell me which speedo (in the dash) u wanna run and what speedo drive u have in the g/box
[Updated on: Wed, 02 April 2003 14:15]
bexi
Re: electronic speedo on 20v??? Thu, 03 April 2003 06:05 Go to previous messageGo to next message
yes i am using a std ae82 analogue speedo.
that's what i was hoping, that i could just use the speedo drive out of a std ae82 gear box and just put in the 20valve gear box... is it that simple?
thanx
bexi
sideshow
Re: electronic speedo on 20v??? Thu, 03 April 2003 08:57 Go to previous messageGo to next message
im pretty sure its that simple
is yr car originally carby
cause if it is then the back of the speedo in the dash has no electronic output for the speed signal into the ecu
if u dont have the speedo signal to the ecu it doesnt matter much its just if u hook up a warning light then it will flash when u drive
if yr car was efi b4 hand then all u have to do is connect the spee signal wire to the correct pin on the 20v computer
shano2
QLD - Sunshine Coast
Re: electronic speedo on 20v??? Thu, 03 April 2003 08:59 Go to previous messageGo to next message
Yes it is!!!!!
sideshow
Re: electronic speedo on 20v??? Thu, 03 April 2003 09:11 Go to previous message
well u can do 2 things
not worry bout speed signal and dont hook up warning light
or
get a dash out of an efi corolla same model as yours
then run a wire from back of dash (speedo signal) to the ecu
then run a wire from back of dash from warning light to ecu
this way it will all be like standard and its easy when checking codes
Previous Topic:What do these do (18R)?
Next Topic:Fuel injectors
Current Time: Mon Nov 9 03:32:39 UTC 2026
Total time taken to generate the page: 0.088850021362305 seconds
