Toymods » Tech & Conversions » 1jz owners
1jdave
1jz owners Wed, 02 April 2003 21:12 Go to next message
anyone experienced like a flat spot at operating temp after deceleration when they go to accelerate again usually in 2nd like its over fueling for a .25 sec
Re: 1jz owners Thu, 03 April 2003 02:40 Go to previous messageGo to next message
dude... learn to use punctuation!
cant actually help with the problem, as mine is currently in limp mode, with 1 and a half ecus Razz
frebbles
Re: 1jz owners Fri, 04 April 2003 00:51 Go to previous messageGo to next message
flat spot or really breif turbo lag?
No I cant say I've noticed...Check your fuel regulators or maybe something else with the fuelling,...
Are you running extra boost?
celicamad
newcastle
Re: 1jz owners Fri, 04 April 2003 12:11 Go to previous message
iv'e noticed this a couple of times .the causes where _
1. loose intercooler hoses or a vaccum hose come a drift
2 . boost controllers - if you use a turbosmart gated or dual stage or any similar pressure relief sysytems the wastegate can be locked open by boost .ebc of any kind wont cause this
3. change your plugs use NGK bkr6es .if you use a fuel cut defender make sure the boost cut isnt set any higher than about
18 psi .otherwise you can effect the map signal too much .
My wifes Cressida behaved similar to this from the same thing .boost cut was set to 20 psi and the car ran too rich .and was VERY laggy (after a boost run)
Previous Topic:AE92
Next Topic:ct26 turbos - 7m vs 3s
Current Time: Wed Nov 18 22:12:24 UTC 2026
Total time taken to generate the page: 0.0047261714935303 seconds
