Toymods » Tech & Conversions » ct26 turbos - 7m vs 3s
gabe
ct26 turbos - 7m vs 3s Thu, 03 April 2003 13:24 Go to next message
not sure if this has been covered before but is the 7mgte ct26 the exact same turbo as my st185 ct26??
(aside from the twin entry housing)
and which makes a better subject to hi flow/rebuild??
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: ct26 turbos - 7m vs 3s Thu, 03 April 2003 23:51 Go to previous messageGo to next message
Have you done a search??
CrAiGzEE
south of the big smoke
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 00:11 Go to previous messageGo to next message
http://www.raceworx.com/funnypics/search.gif
i love that!!
quickly
3s
dual entry
ceramic wheel
7m
single entry
steel wheel
Cyber-punk
Brisbane, QLD
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 04:50 Go to previous messageGo to next message
whats the difference between dual entry and single?
gabe
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 04:52 Go to previous messageGo to next message
yes i always do a search before asking a question
came up trumps though Rolling Eyes
TE72_Turbo
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 08:13 Go to previous messageGo to next message
7M - steel exhaust wheel, no limit on boost, plus larger compressor wheel standard than 3S.
I've got the best of both worlds for sale in the "parts for sale" section. Its already been hi-flowed & has steel exhaust wheel. You can use the single or twin entry exhaust housing, depending what you are bolting it to.
http://www.toymods.org.au/msgboard/index.php?t=msg &th=11976&start=0&rid=102&S=eb157d 138153868bbb34627cf1a48a3e
TA22-3SGTE
MACKAY
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 09:55 Go to previous messageGo to next message
ST165 3SGTE = steel wheel ,single entry , 40mm comp wheel
ST185 /205 = ceremic wheel , twin entry , 40mm comp wheel
7MGTE = steel wheel , single entry , 47 mm comp wheel plus larger exhaust housing but has same size exhaust wheel .
Trevor
gabe
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 10:24 Go to previous messageGo to next message
thanks trevor, so a 7m is a better starting point...ok
bummer Rolling Eyes
TA22-3SGTE
MACKAY
Re: ct26 turbos - 7m vs 3s Fri, 04 April 2003 10:54 Go to previous message
Yes 7M is a better turbo to start with .
Trevor
[Updated on: Fri, 04 April 2003 10:55]
Previous Topic:1jz owners
Next Topic:auto to manual converstion MA61
Current Time: Wed Nov 18 22:32:21 UTC 2026
Total time taken to generate the page: 0.0058751106262207 seconds
