Toymods » Tech & Conversions » 1g-gte engine in a hilux
elie
icon10.gif  1g-gte engine in a hilux Wed, 15 May 2002 05:55 Go to next message
i was wondering if anyone knows anything about putting a supra 1g-gte engine into a hilux i need any information i can get
Corvid
Re: 1g-gte engine in a hilux Wed, 15 May 2002 06:07 Go to previous messageGo to next message
Ive heard the M series motors are the way to go.. Due to the huge support for the conversion kits avail..
more torque also.. which is what you want.
stradlater
Arthurs Creek, Victoria
Re: 1g-gte engine in a hilux Wed, 15 May 2002 06:13 Go to previous messageGo to next message
I personally have seen a number of conversions of a 1g into a hilux. One by the lesser respected - racecraft - and one by a independant guy. I know these things go nana's in a hilux, I would say go for it.
Small ute with a light weight motor. Hrm, I can't seem to see the downside.
Mr_Fusion
Re: 1g-gte engine in a hilux Wed, 15 May 2002 06:15 Go to previous messageGo to next message
Go either the 1GGTE or the 7MGTE dude, they both put out similar power figures....
ed_ma61
Lost in the K hole
Re: 1g-gte engine in a hilux Wed, 15 May 2002 07:09 Go to previous messageGo to next message
TOURQUE
i got caught up in this argument no less than 3 weeks ago.
SUMMARY: 1ggte likes to rev its tits off, and doest hit maximal tourque til late in the rmp range. M series, tourque from the get go. similar power outputs on the dyno, but completely different to drive.
ed
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon4.gif  1G-GTE vs 7M-GTE Wed, 15 May 2002 07:40 Go to previous messageGo to next message
Yup. Similar power, but there are big differences which make one more suitable than the other in different situations.
Arrow 1G-GTEs are perfect for light cars. It's much lighter, smaller, and more fuel efficient. And they love to rev.
Arrow 7M-GTEs should go in the heavier cars where their torque will make a difference. The only problem for a 7M-GTE is that if it'll fit in an engine bay, so will a 1JZ-GTE...
Fattony
icon10.gif  Re: 1G-GTE vs 7M-GTE Wed, 15 May 2002 08:21 Go to previous messageGo to next message
Strad mate, the hilux racecraft have sitting there has a 4ag in it (cant remember, which varient). All the same im told by the owner of a fairly modified hilux that they are a heavy vechicle, well compared to small cars anyway, so i would suggest you ditch the idea of the 1g, there would not be enough torque down low to get that thing moving well of the start, if it were me i would dump in a 7m-gte.
Johnny
Sydney, OZ
Re: 1g-gte engine in a hilux Wed, 15 May 2002 11:32 Go to previous messageGo to next message
The 1G engine will bolt straight into any of the hilux's post 85 up to 98 (RN85). The main reason are that the RWD Celica's share many of the part's in the hilux's. Slight massaging of the firewall is need to fit a 1G engine into the hilux. The Drivetrain will handle (diff) the 1ggte or ZE power or torque quite easily. (HILUX 2" shafts Vs celica's 1" stuff) and gearboxes for the 1G will bolt up to the hilux X-member and so will the driveshaft. As for the 7M a late model 1GGTE or a earlier model 1J (JA-70) engine would be choice, ie 2.0L or 2.5L turbo would be easly engineered over a 3.0L Turbo, plus the I'm not 100% the length of the 7M hence fitting to the hilux drive train. Also a 3VZ (3.0L) or 5VZ (3.5L) with the TRD supercharger (US) would be by far even easier with just a change of bellhousing (4Runnner) to get a bigger capacity engine and similar power to the 7M.
Nark
Cabramatta, NSW
icon5.gif  Hilux weight Wed, 15 May 2002 13:38 Go to previous messageGo to next message
How much do Hiluxes weigh anyway?
3sgte-ae86
Mackay, QLD
icon8.gif  Re: Hilux weight Thu, 16 May 2002 03:36 Go to previous messageGo to next message
My friend has just built a 1990 hilux with a 1ggte in it. It took 10 months and approx $18000 to build. As far as fitting the engine we fitted a supra box, (original g/box mounts) 12mm plate to move the engine mount holes foward 50mm and two t/fans. Took a day of work and got it registed and blue plated drove it 200km's and got it weighed 1380kg. Then we were driving it to get a wheel alignment and a women pulled out in front of us. $15000 worth of damage.
Les
Re: Hilux weight Thu, 16 May 2002 04:07 Go to previous messageGo to next message
Rolling
why not get a 1jzgte ? the 2.5 tt engine ?
my friend who did my conversion is actually thinking of putting one of these in his Hilux !
of course that is after he has finished with putting a VR-4 in his Cordia !!
[Updated on: Thu, 16 May 2002 04:07]
Johnny
Sydney, OZ
Re: 1g-gte engine in a hilux Thu, 16 May 2002 10:15 Go to previous messageGo to next message
My '93 2wd weighed in a 1200Kg. This could be less if I had an Alloy tray (close to 1150 or less) 4WD version?? have to be at least 1300Kg.
Are you sure... Because NRG in Sydney we're one of the first to fit a 1GGTE in to a Lux, Have detailed photo's of the conversion and it was outlined in Hot4's Issue 20 and there was no moving of engine mounts I'm definately 100% sure the whole 22R engine and gearbox bolts straight into a Corona and celica and I'm 100% sure that the distances between the gearbox mount and engine mounts on the 1GG's match this perfectly, only the height becomes a problem. I also know was the price of the 1GGTE's in 1994 stopped me from fitting one to my hilux which ended the same way as your mates.
3sgte-ae86
Mackay, QLD
Re: 1g-gte engine in a hilux Fri, 17 May 2002 05:43 Go to previous messageGo to next message
This hilux was fitted with a 3y factory which made the engine mounts and g/box different. So yes the 22r hilux has a supra box standard. There was no problem with height as it sits very low in the bay and has single turbo and custom inlet manifold.
knackers
berala sydney
Re: 1g-gte engine in a hilux Fri, 15 November 2002 10:32 Go to previous messageGo to next message
hi am about to put a 1ggte into my 1991 hilux i was wondering if you could send me photos or any info please any thing would help.What engine mounts were use (the ones on the 1ggte motor alloy or steel) gear box ect ect what ever you got would help get this project up and smoking. thanks
juzzo84
Hornsby, N.S.W
icon12.gif  Re: 1g-gte engine in a hilux Fri, 15 November 2002 13:41 Go to previous messageGo to next message
if anyone wants information on 1g-gte installations into a hilux, talk to TULLY at www.easystreetcustoms.com
they deal with mini trucks and they have done the 1g conversion and others very similar to it.
JUZZO
stradlater
Re: 1g-gte engine in a hilux Fri, 15 November 2002 14:15 Go to previous messageGo to next message
Fattony: The Hilux I'm referring to at Racecraft DID have a 1g-gte in it, I don't know which one you are talking about, but the one I'm talking about had a 1g-gte. As for weight, as far as utes go, I get the feeling that's like, and it has a light arse end.. All the more fun.
purpleminiep
Mentone
Re: 1g-gte engine in a hilux Sat, 16 November 2002 01:58 Go to previous messageGo to next message
My froend has just put a 1ggte into a petrol Bundera. Half Hilux Half Cruiser. Does anyone know what box is in the car and what sort of punishment it will cope with.
Brad
juzzo84
Hornsby, N.S.W
icon12.gif  Re: 1g-gte engine in a hilux Sat, 16 November 2002 03:12 Go to previous messageGo to next message
the guy i know that did the conversion used a supra box, because he was not happy with hilux ratios.
JUZZO
juzzo84
Hornsby, N.S.W
icon12.gif  Re: 1g-gte engine in a hilux Sun, 17 November 2002 02:56 Go to previous messageGo to next message
YOU GOT MAIL:
did you get a chance to talk to tully at easystreet???
JUZZO
knackers
berala sydney
Re: 1g-gte engine in a hilux Sun, 17 November 2002 10:06 Go to previous messageGo to next message
yer thanks juzzo rang him but his bat when flat but will ring tomorro at work to sort all out
thank once again juzzo
knackers
juzzo84
Hornsby, N.S.W
icon14.gif  Re: 1g-gte engine in a hilux Sun, 17 November 2002 12:14 Go to previous message
Smile No worries KNACKERS, glad i could help.
CATCHA
JUZZO
Previous Topic:Anyone have pics of their 18RGeu AFM/uniFlow?
Next Topic:RT104 generations
Current Time: Tue Oct 27 04:19:56 UTC 2026
Total time taken to generate the page: 0.085289001464844 seconds
