Toymods » Tech & Conversions » help with ECU relations to engine.
qQFoB
NY, USA
help with ECU relations to engine. Sun, 06 April 2003 04:17 Go to next message
i have here a 3SGE from a 94 Celica. i brought the ECU a year ago on Ebay and it was stated "supposedly" to be for a 95 MR2 3SGE. i recently got the wire harness for a 95 MR2 and was going to do the swap on my US 91 MR2. when i recieved the harness, i noticed that the ECU plugs does not fit the ECU. the harness has 4 ECU plus which i assume is the correct one, but my ECU is 3 plugs (26p,16p,22p).
now obviously i have gotten the wrong ECU. i tried to find information on the ECU using a downloaded EPC, but i have found nothing on it. there is no match for the ECU to any car. i hope someone can help me find the correct car this ECU goes to so i can see if i should rewire it or sell it.
on the ECU, the Toyota label has a part number 89661-20712. under that has the serial number 175700-2832 12V. its a 3 plug ECU with the plugs 26P, 16P and 22P. it also says 3S-G and A140E.
please help me with all the information available. also, i will be looking to purchase a 4 plug 3SGE ECU part number 89661-17500, so if anyone has one laying around, please help. thanks.
sideshow
Re: help with ECU relations to engine. Sun, 06 April 2003 04:57 Go to previous messageGo to next message
does the harness seem to match up to the engine
i think all australian mr2's have 3 plugs on the ecus
maybe the harness is wrong
im not to sure how american ecus or harnesses are like
qQFoB
NY, USA
Re: help with ECU relations to engine. Sun, 06 April 2003 05:27 Go to previous messageGo to next message
the harness matches up completely with the engine. matches from every sensor to length of wiring to the sensor.
i recieved the harness from UK, which should be the same with Japanese ones.
im not sure what country or what car the ECU came from, but most likely not the US because the US doesnt get n/a 3SGEs. it is not a 3SGTE ECU because i have tried to plug it up to a 3SGTE and it runs, but car doesnt move other than idle, and doesnt boost.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: help with ECU relations to engine. Sun, 06 April 2003 10:22 Go to previous messageGo to next message
That "3S-G and A140E" sounds like it's for a 3S-GE with an auto gearbox.
sixworks
Newcastle, NSW, Australia
Re: help with ECU relations to engine. Sun, 06 April 2003 11:43 Go to previous messageGo to next message
I have a 3SGE ecu from an MR2 but it is still in Japan. I'll get pin configuration checked.
Grant
sixworks
[Updated on: Sun, 06 April 2003 11:44]
Re: help with ECU relations to engine. Sun, 06 April 2003 11:46 Go to previous messageGo to next message
Don't newer Toyotas have computer controlled transmissions, so is the extra plug for controlling the automatic gearbox?
sixworks
Re: help with ECU relations to engine. Mon, 07 April 2003 05:57 Go to previous messageGo to next message
Sorry, pin configuration is the same as Oz spec ecu's.
Grant
qQFoB
NY, USA
Re: help with ECU relations to engine. Mon, 07 April 2003 20:58 Go to previous messageGo to next message
auto gearbox? i talked to someone recently that made me believe its possible that its from a Lexus brand thats why it didnt show up on my EPC.
i dont think auto has the extra plug, rather it has a seperate ECU for the trans.
whats this Oz spec you are talking about? is your's a 94-96 MR2 ECU? how many pins is it?
sixworks
Re: help with ECU relations to engine. Mon, 07 April 2003 21:46 Go to previous message
The part number is 89661-17280 with pin config is 24P-16P-22P.
Previous Topic:GZE into AE82. Speedo & tacho help
Next Topic:Back-fire 2TG...
Current Time: Fri Nov 20 13:14:13 UTC 2026
Total time taken to generate the page: 0.00496506690979 seconds
