Toymods » Tech & Conversions » How much to replace oil seals on turbo?
CeLiCa
How much to replace oil seals on turbo? Sun, 06 April 2003 14:07 Go to next message
I am wondering how much it generally costs to replace the oil seals on a turbo. My friend has a CT20b with stuffed oil seals. How much does this generally cost to fix if the turbo is removed from the engine and taken to the shop?
manipulate
Re: How much to replace oil seals on turbo? Mon, 07 April 2003 11:40 Go to previous messageGo to next message
I also would like to know this...
Ta
Mani
gussyboy2
Oxenford/gold coast
Re: How much to replace oil seals on turbo? Mon, 07 April 2003 23:37 Go to previous messageGo to next message
if this is relating to oil coming out of dump pipe
1st check oil pressure
i just went through this trouble and some turbo specialists told me oil seals and some said the oil pressure was too hi going to the tubo's. when we checked the pressure in the turbo oil line it was 100psi at idle
TE72_Turbo
Re: How much to replace oil seals on turbo? Tue, 08 April 2003 13:10 Go to previous messageGo to next message
agreed. the rear seal on toyota (& many other OEM)turbos are no more than a single ring seal, like a piston ring. if you pump too much oil into the core, it saturates the rear of the shaft, & it only takes a poofteenth of oil through the ring seal to make a lot of smoke.
If the seal is worn beyond its limit, a turbo shop is likely to charge you labour to dismantle & reassemble the turbo, bead blast the exhaust wheel & possibly rear of the core, plus re-balance the shaft & wheel assembly. Most will recommend putting a complete kit through the turbo (bearings etc) while its apart. If you can convince them to replace the seal only, expect to pay around $200 ($70 labour, $6 seal, $120 balance). Its a lot of labour for a part worth under 10 bucks.
Phil
gussyboy2
Oxenford/gold coast
Re: How much to replace oil seals on turbo? Thu, 10 April 2003 08:39 Go to previous messageGo to next message
thanx phill for info on prices for seals etc
bit better than $600 each hey
recently found out too much oil pressure causing
oil to piss out through seals
hopefullyt havn't stuffed the seals with oil probs
fingers crossed so far
gus
TE72_Turbo
Re: How much to replace oil seals on turbo? Thu, 10 April 2003 10:58 Go to previous message
I reckon it should be fine. It would take more than excess oil pressure to damage a ring seal, unless perhaps you'd done 50,000km like that.
Previous Topic:4AGTE owners: where does your oil drain go?
Next Topic:Need Wiring Diagram
Current Time: Thu Nov 19 19:34:06 UTC 2026
Total time taken to generate the page: 0.0061280727386475 seconds
