Toymods » Tech & Conversions » Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT
mad660
Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 07 April 2003 07:17 Go to next message
No Message Body
freakysoarer
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 07 April 2003 08:44 Go to previous messageGo to next message
no.
u need one from a TT manual soarer.
which are quite hard to come by...
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 07 April 2003 09:21 Go to previous messageGo to next message
>no. u need one from a TT manual soarer. which are quite hard to come by... <
WHAT? What planet are you on? YES you can use the 5 speed from behind the 2JZGE and YES you can use the 6 speed from the 2JZGTE.
Both of these will bolt straight to the motor. You will need the flywheel and clutch setup that came with the box as well as (most likely) a custom tailshaft. You may need to alter the gearbox crossmember - again it's not really that common a swap so it's just a matter of doing it and seeing how it lines up... and working from there.
Not sure about tunnel clearance. The 5 Speed will fit easily, the 6sp will be fairly close but should go with no or maybe minimal complication.
The 5 speed from a 1JZGTE is still the easiest solution though.
Pete
gold coast
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 07 April 2003 10:46 Go to previous messageGo to next message
I have never seen one, but word is that VVT-i soarers could be optioned with a V161.(JZA80 6 Speed) I have heard there are a few of these cars in the country.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 07 April 2003 21:59 Go to previous messageGo to next message
It's not factory, but there's one kicking around on the coast with a 6 speed behind it... rego plates are CCN00 or something like that. It was featured in zoom a while back if I remember. So they definitely fit.
freakysoarer
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Tue, 08 April 2003 07:31 Go to previous messageGo to next message
7M-Brisbane wrote on Mon, 07 April 2003 19:21
you will still need a bellhousing and shifter to fit though...
from a manual soarer...no? if so, wouldn't it be far easiler to source both together?
then again, maybe i'm wrong and misread it somewhere...
Pete
gold coast
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Tue, 08 April 2003 07:50 Go to previous messageGo to next message
AFAIC, the Supra is based on the Soarer Floor pan. Therefore the shifter position is the same.
The bellhousing between a 2J and 1J is the same. (if you are paying +$3500 for a box, i'd want the bellhousing.)
Bounty
_Sydney _
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Tue, 08 April 2003 08:46 Go to previous messageGo to next message
So whos gona donate me $3500??? Very Happy
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Tue, 08 April 2003 10:37 Go to previous messageGo to next message
I donm't profess to know everything, but if you don't know what you're talking about, can you PLEASE not give advice to people?
Anything that bolts onto a 1JZ will bolt onto a 2JZ and versa.
freakysoarer
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Tue, 08 April 2003 11:22 Go to previous messageGo to next message
i nv did say i know everything...
and i nv said that anything about a 1JZ not being able to bolt onto a 2JZ.
neither did i say that the box from a supra is not compatible to a soarer.
i only indicated that you need a bellhousing and shifter from a manual soarer if you are getting a r154 box from a MKIII supra.
and that if so, its better to get the box from a manual soarer since you will need the bellhousing and shifter anyway.
the only mistake i made was that I misread the title.
I had thought that the conversion was from a MKIII, since its not as straightforward as bolting it in.
any inconvenience caused is regretted.
7M-brisbane : I apologise for misinformation and misunderstanding. Thank u 4 correcting me.
SUPRA MAN
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 08:33 Go to previous messageGo to next message
I have been enquiring about putting a getrag 6 speed into my 1988 toyota supra. Technically the 6 speed is EXACTLY the same as the R154 5 speed, except it has an extra overdrive for top end speed. There is little, if any difference in 1st, 2nd, 3rd, and 4th gear with the R154 5 speed and Getrag 6 speed. This was relayed to me by a mechanic who built, and used to work on a Production racecar JZA80 RZ supra with a 6 speed getrag gearbox.
So why would you spend an extra $2,000 on a 6 speed, when it is only for top end speed, over 200km/hour, not for low down acceleration ???
This is only what I have heard, so dont shoot the messenger if you have heard different.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 09:01 Go to previous messageGo to next message
freakysoarer wrote on Tue, 08 April 2003 21:22
(blah blah blah)
(blah blah blah)
Erm... just so that you know.. the part that allows a gearbox to BOLT to an engine is the bellhousing. So if a box bolts up that means that the bellhousing is right. So why, if the box bolts up, would you need the other bellhousing?
One from a JZA70 Mk3 Supra would bolt up too.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 09:08 Go to previous messageGo to next message
SUPRA MAN wrote on Wed, 09 April 2003 18:33
I like shooting messengers.
Your information is completely flawed and I would suggest not going to that mechanic. The R154 5 speed is a TOYOTA built gearbox. The V160/V160 6 speed is a GETRAG box. As in built by a completely different company.
That's like saying that a Celica is like a Ferrari but that the Ferrari has a bigger engine.
The getrag is HEAPS better than the Toyota box.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 09:18 Go to previous messageGo to next message
Here's one I prepared earlier:
http://www.turbosupras.com/~jbstenner/images/r154vsv160.jpg
And here's another:
http://www.turbosupras.com/~jbstenner/images/R154andV160-1.jpg
Notice how even externally they look completely different with different casings, input shafts and shifter setups, as well as being a completely different shape.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 09:31 Go to previous messageGo to next message
I might add that the V160 does not have an extra overdriven gear; only 6th is overdriven, and 5th is 1:1. Therefore the 6th gear isn't just there for top-end speed, instead it's there to make the ratios closer.
SupraMan, I don't care if you're just the messenger, you shouldn't go around spreading misinformation like this when you obviously don't know what you're talking about. Confirm your facts first, then share them with the rest of us.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 09:49 Go to previous messageGo to next message
From now on, you will be called 'Baghdad'. You shall not be shot, but annihilated.
The beautiful pictures posted above demonstrate they are not in fact the same box, but instead, rather different boxes.
You also claim that the first 5 ratios are the same/similar to the R154. In fact, they are not.Here are the ratios.
V160 R154
1st 3.827 3.251
2nd 2.360 1.955
3rd 1.685 1.310
4th 1.312 1.0
5th 1.0 .753
6th 0.793 N/A
Rev 3.280 3.18
As you can see, they are not similar at all. There is only one overdriven gear in the six speed contrary to the 2 you conjured up.
Personally, I find it hard to justify the money to buy the 6 speed because I am a tightarse and because I can't be fagged with the tunnel revisions required to make it fit in my Corona Mk2. However, it is the silkiest, smoothest, most robust box. Given only a small amount of coersion.......
So 'Baghdad', I suggest you speak to you production racecar wankanic (who will be now referred to as 'Basra') and tell him he is a complete cretin who can barely handle a spanner, let alone string together a coherent, factual sentence.
This information was all obtained via the internet with a minimum degree of effort.
Please refrain from spouting shit......it annoys the fuck out of some of us.
Cheers Dave.
Stenno
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:01 Go to previous messageGo to next message
Good luck fitting a Getrag - the bellhousing is part of the gear casing, which makes fitting it onto anything else rather painfull.
Gear ratios are totally different
V160 ratios
First 3.827
Second 2.360
Third 1.685
Fourth 1.312
Fifth 1.000
Sixth 0.793
Final drive is 3.267
R154 ratios
First 3.251
Second 1.955
Third 1.310
Fourth 1.000
Fifth 0.753
Final drive is 3.73
And when it comes to comparing the V160 to the R154, the R154 is a POS in comparison, no 2 ways about it.
Dave, you beat me to it Smile
[Updated on: Wed, 09 April 2003 10:05]
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:10 Go to previous messageGo to next message
SUPRAMAN, you're my hero http://www.performanceforums.com/~shifty/flipoff.gif
wastegate
Gold Coast
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:16 Go to previous messageGo to next message
http://www.jzgte.com/~nickc/images/general/owned/soccerowned.jpg
Sorry just had too. Been saving that one for a while.
SUPRAMAN does a bit of this too.http://www.supraforums.com/images/smilies/wackit.gif
SUPRA MAN
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:19 Go to previous messageGo to next message
ok guys, I was expecting some feedback. As I said, it was only what I heard. I hadnt done any research, and i want to learn as much as i can. I'm happy to have you guys tell me as much as you can, as i would like to learn as much as I can.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:23 Go to previous messageGo to next message
Baghdad, from here on if you preface everything you post with the following phrase,
"The following statement has no basis in fact whatsoever,"
we'll get on just fine.
Cheers Dave.
[Updated on: Wed, 09 April 2003 10:23]
SUPRA MAN
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:27 Go to previous messageGo to next message
c'mon guys, I said that was what I heard, not my opinion.
I posted it to see if that was true or not. I didnt say it was true, I said it was "what I had heard" How else am I going to find out if I dont ask people that know, like you guys here on toymods ??
wastegate
Gold Coast
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 10:29 Go to previous messageGo to next message
Two things that are a LAW with the internet, don't believe what the yanks say with Supras, they are as bad and worse as yourself with information next is take a UN sized bag of slat with you when you read the camel poop that is on the Internet.
Getrag are gearbox gods!
I've broken my R154 3 times (yes that thrust washer that MD has just found out about) took until the 3rd time to work out it's a flaw and $3000. You just don't hear about these problems with the V160! If you have a JZ engine and you have the money get a V160! I don't care how you fit it because it's worth both kidneys and 12L of blood.
I evny you Stenno! :p~~~~~ v160 ~~~~
Apollo
Brisbane, QLD, Australia
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 11:53 Go to previous messageGo to next message
So after all the discussion of telling people how wrong they are, can this be answered: ?
Will a 6 speed box from a supra (2jz), fit straight onto a 1JZ TT in a soarer? There's a bit of contradiction by some people here so far.
The 6 speed is a V160 made by a company called getrag. Did I pick that up correctly?
Thanks.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 11:55 Go to previous messageGo to next message
I thought this had already been answered, but yes, you can put a Supra 6-speed behind a 1JZ. All JZ series engines have the same bellhousing bolt pattern, so the transmissions are interchangeable - the only catch is you have to swap the flywheel and clutch along with the transmission (but again these are interchangeable).
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Wed, 09 April 2003 12:27 Go to previous messageGo to next message
For fuck's sake, if you can't read you shouldn't be doing a gearbox conversion.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Thu, 10 April 2003 01:04 Go to previous messageGo to next message
Apollo, read the entire thread again SLOWLY and use a dictionary for the words you don't understand. It's quite simple really. The only contradiction stems from the idiots that reckon..... Rolling Eyes
[Updated on: Thu, 10 April 2003 01:06]
SUPRA MAN
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Thu, 10 April 2003 02:47 Go to previous messageGo to next message
gianttomato wrote on Thu, 10 April 2003 11:04
Some people need to calm down and remember that this is a place to share and gain information. Just because you think you know what you are talking about, it doesnt mean everyone else does.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Thu, 10 April 2003 09:19 Go to previous messageGo to next message
"Some people need to calm down and remember that this is a place to share and gain information. Just because you think you know what you are talking about, it doesnt mean everyone else does."
We are calm.. it's just that we've been less than subtle and still some people don't know the answers. It's like the idiots I deal with at work... I can say things a hundred times but they stiiiiiiill don't understand.
Apollo
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Thu, 10 April 2003 10:24 Go to previous messageGo to next message
You were saying?
Postcount = + 1.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Thu, 10 April 2003 11:28 Go to previous messageGo to next message
You would make a good lawyer - you're full of shit and good at twisting things around to confuse people (yourself included). Are you trying to say that I contradicted myself? If so, you're sadly mistaken.
If you read (you CAN read, can't you?) through the thread, post by post, you'll notice that it turns from one topic to another. The question was:
"Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT".
This was answered rather succinctly. Yes you can, and yes any of these gearboxes will bolt STRAIGHT UP WITHOUT NEEDING A DIFFERENT BELLHOUSING OR ANY OTHER MODIFICATIONS.
Then the subject turned - as a result of some uneducated drawl by SUPRAMAN - to the differences between the R154 behind the 7MGTE and the V16x behind the 2JZGTE. This was illustrated rather clearly by a picture of said gearboxes side by side.
You seem to relate the comments I made regarding the 7M R154 vs 2JZ V16x back to the original post, when the topic had by that point clearly changed.
Don't post any more, you're wasting bandwidth.
[Updated on: Thu, 10 April 2003 11:42]
Apollo
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Fri, 11 April 2003 02:11 Go to previous messageGo to next message
Ok, I admit my mistake of overlooking the fact it was an '88 supra that the discussion had turned to.
If you had figured out how to use the edit function of this forum and inserted them into your post directly targeting the supra matter, then the pictures you posted would have made more sense.
As for your attitude, and GT's, well, that's your own problem if you need to be an arsehole to people from behind a computer on a forum to make yourself feel better.
Ah yes, thankyou Norbie for a precise no bullshit answer.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Fri, 11 April 2003 13:53 Go to previous messageGo to next message
7M-Brisbane wrote on Thu, 10 April 2003 21:28
Apollo, pay attention. Read slowly and use the dictionary - it's your friend.
Apollo
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Fri, 11 April 2003 14:52 Go to previous messageGo to next message
gianttomato wrote on Fri, 11 April 2003 23:53
I suggest you take your own advice.
Don't use terms like 7m has, and uses them in a context that he doesn't understand.
You might find YOUR dictionary half used in your toilet.
Now you will be called Opinion.
Because opinions are like like arseholes, and you are just one big opinion.
I was going to let the incorrect use of the term 'bandwidth' slide, but, you just couldn't help yourself by trying to prove you are better than everyone else.
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Sat, 12 April 2003 01:11 Go to previous messageGo to next message
Bandwidth these days has come to be used almost as a slang word. I apologise for using the word in it's socially acceptable pretense. For a guy who constructs sentences like...
...you're mighty critical of other people's work.
As for saying I'm out of line, I hardly think so. I think it's outrageous that idiots on these forums would blabber about things they don't understand - and that some poor bugger might actually take the advice of these people.
Finally - had you actually followed the thread rather than barging in here and making useless comments, it would have been stunningly clear exactly what I was talking about. Oh, and who's the keyboard warrior? I can't find one piece of information you've posted in this thread that even borders on being constructive, yet you point out one single line from one of my posts in the hope that you can save face and your buddies will think you're 'the man'.
EDIT: I was disappointed when I checked your profile to find (from your date of brith) that you were actually an adult. I had hoped you were just some young kid who had a chance to grow up.
I might suggest that this conversation should end now before the drivel continues.
[Updated on: Sat, 12 April 2003 01:15]
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Sat, 12 April 2003 03:24 Go to previous messageGo to next message
for supposed adults, you guys can shit sling with the best of the kiddie internet commandos out there Smile
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Sun, 13 April 2003 00:37 Go to previous messageGo to next message
A quote from the recent war (I believe this came from Dubya himself):
"All a good man must do for evil to succeed is nothing" Very Happy
I'm not going to sit here while these people give out incorect advice and/or act as if I'm full of it.
Like I said though, this thread is over, the topic has been answered Smile
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Sun, 13 April 2003 05:01 Go to previous messageGo to next message
I think you'll find Dubya ain't that eloquent... he was quoting Edmund Burke (1729-1797):
"The only thing needed for evil to prosper is for good men to do nothing."
Smile
7M-Brisbane
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Sun, 13 April 2003 06:59 Go to previous messageGo to next message
Well there you go. I'm misquoting a quote of a quote Smile
Apollo
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 14 April 2003 03:12 Go to previous messageGo to next message
Ok, I apologise to the rest of the forum for letting myself be brought down to the low level of throwing insults around.
I've already apologised for where I stumbled with the '88 supra being thrown in.
That's it from me in this topic. I'd say more, but, the fire doesn't need anymore fuel to have an excuse to flare up again.
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 14 April 2003 04:08 Go to previous messageGo to next message
Norbie wrote on Sun, 13 April 2003 15:01
I think you'll find Dubya ain't that eloquent....
Dubya is a cack. His English skills are less than 'tidy'.
My favorite quotes followed soon after the September 11 tragedy.
"Osama Bin Laden - wanted dead or alive...."
"They have siddled round, side stepped....crawfished aroung the issue of giving him up...."
Yep, he's a Texan!
Esteban
Brisbane - Chapel Hill
Re: Can I put a JZA80 or later model supra 6 speed or 5 speed in to a JZ Soarer TT Mon, 14 April 2003 10:47 Go to previous message
Shuddup ya bunch of skirts!
Previous Topic:ke 10 conversion
Next Topic:never mind
Current Time: Sun Oct 25 23:14:18 UTC 2026
Total time taken to generate the page: 0.09748387336731 seconds
