Toymods » Tech & Conversions » 4agte fuel requirements?
sebta22
4agte fuel requirements? Tue, 08 April 2003 02:19 Go to next message
I have seen a relatively cheap fuel pump at Marlows which pumps out 1.8L/min. This seems very low, is it enough fuel to feed a surge tank for a 4agte? What do other people have for both surge tank feed and efi pressure pump??
Re: 4agte fuel requirements? Tue, 08 April 2003 02:45 Go to previous messageGo to next message
Your injectors will tell you the answer. Let's say you are running 440 cc/minute injectors. At 100% duty cycle, they are flowing 440 cc/min or 0.440 l/min. Multiply that by 4 (the number of cylinders you have) to give you your total maximum fuel requirement, 1.72 l/min.
Of course, you won't be running your injectors at 100% duty cycle, and you are probably going to run smaller injectors.....anyway, you do the maths.
TE72_Turbo
Re: 4agte fuel requirements? Tue, 08 April 2003 13:01 Go to previous messageGo to next message
will the return line from your fuel rail be going to the surge tank, or back to the main tank? what are you using as the main pump from the surge tank to the fuel rail?
sebta22
Re: 4agte fuel requirements? Thu, 10 April 2003 01:42 Go to previous messageGo to next message
I am looking at having the fuel rail return back to surge tank. I dont know yet what i'll use, maybe VL turbo pump?? any suggestions, still using standard 4agze injectors. couldnt a six or eight cylinder efi pump be used?
YOGI8U
up yours!
Re: 4agte fuel requirements? Thu, 10 April 2003 02:51 Go to previous messageGo to next message
vl fuel pump not a problem!
most surge tanks have a fitting in the top, this is for the return from the rail.
Thats how mine is setup.
TE72_Turbo
Re: 4agte fuel requirements? Thu, 10 April 2003 10:43 Go to previous messageGo to next message
If it returns to the surge tank, then you dont need the pump feeding the surgie to be anywhere near the flow of your high pressure pump to the rail. A VL pump will definately be sufficient as your high pressure pump, Your lift pump to the surge tank can be either an EFI pump (provided its lower than the main tank) or a factory style low pressure pump. No need for noisey holley blue or anything.
[Updated on: Thu, 10 April 2003 10:47]
sebta22
Re: 4agte fuel requirements? Fri, 11 April 2003 00:33 Go to previous messageGo to next message
are there any other efi pumps that you can use instead of VL turbo?? how much are VL turbo pumps??
sprinterboy4agze
Re: 4agte fuel requirements? Fri, 11 April 2003 00:39 Go to previous messageGo to next message
ive got a series 5 rx7 low pressure fuel pump and for my high pressure im using a vl turbo pump i got the both for $100
YOGI8U
up yours!
Re: 4agte fuel requirements? Fri, 11 April 2003 03:11 Go to previous messageGo to next message
after reading my reply i relised i left out a few things!
tank to surge i use a facet (I think thats what it is called)
eletric fuel pump rated at about 15 psi
from surge to fuel rail i use a vl turbo pump.
Re: 4agte fuel requirements? Fri, 11 April 2003 03:57 Go to previous message
VL pumps are cheap and easy to get. If you want a second-hand one, you can pick up a JE Camira pump (identical to the VL pump) for around $50. That's what I'm using in my Celica and it's working great. Smile
Previous Topic:St 141 Vacuum Advance
Next Topic:RA65 diff upgrades?
Current Time: Fri Nov 20 01:10:58 UTC 2026
Total time taken to generate the page: 0.0087029933929443 seconds
