Toymods » Tech & Conversions » 3tgte oil? boost presure?
aaronlaaron
geelong
3tgte oil? boost presure? Tue, 08 April 2003 07:28 Go to next message
What sort of oil should i use?? I have ask around and have had many different answers. I have also read on these forms that some people are running as high as 24 psi boost, The most that i can run is about 12psi on optimax with out it pinging.. (I have a supra inter cooler, MTX8 and forgies with a comp of 7.2.) not that i want run more boost I was wondering how can you run such high boost?
gussyboy2
Oxenford/gold coast
Re: 3tgte oil? boost presure? Tue, 08 April 2003 08:52 Go to previous messageGo to next message
when does it start pinging?
at any particular rev?
at any particular psi?
pinging can be fixed by retarding the timing or giving it more juice
email me and let me know how u went
dewgood@bigpond.com.au
good luck
gus
wilbo666
Re: 3tgte oil? boost presure? Tue, 08 April 2003 09:00 Go to previous messageGo to next message
Are you still running the stock injectors?
aaronlaaron
geelong
Re: 3tgte oil? boost presure? Tue, 08 April 2003 09:56 Go to previous messageGo to next message
not to sure what size the injectors are but i dont think that they are standard. What sort of KW should i expect at the wheels from my set up?
thetoyman75
Club President
icon10.gif  Re: 3tgte oil? boost presure? Wed, 09 April 2003 23:50 Go to previous message
Aaron,
You should be able to run more boost at the expense of ignition timing but if your happy with 12 PSI then just leave it as is. A few more PSI does/can make a big difference then especially with a Compression ratio of 7.2 !!!
As for oil I use BP course plus in my 2TG's (includeing my 2TGTEU) was recommended to me buy a guy who runs a 3TGTE and gives it alot of abuse. I've been really happy with it.
Just avoid anything to thin as they are an old engine with large tolerances !
Previous Topic:4AGE / 20V bolt pattern differences
Next Topic:1JZ-GTE with MicroTech & Bosch 910 Fuel Pump + Info on Stepper Control on MicroTech/Haltech?
Current Time: Thu Nov 19 12:13:15 UTC 2026
Total time taken to generate the page: 0.0050230026245117 seconds
