Toymods » Tech & Conversions » Cooling sys rwd 4ag?!?!
twincam_ke20
Castlemaine Vic
icon5.gif  Cooling sys rwd 4ag?!?! Tue, 08 April 2003 10:52 Go to next message
okay, got a fwd 4age, water return pipes? outlets what ever they are run along the side to the rear of the motor....Do i just have to get a rwd water pump for one, and will it bolt straight up, and the other pipe, outlet...rwd one of those too?
or what?
Can i just use the original pipes and just bend/join pieces to it to connect to the thermostat?
what have ppl done here? If anyone has pictures they could show me, would be great, thanks for ya help
thanks for ya help.
TE72_Turbo
Re: Cooling sys rwd 4ag?!?! Tue, 08 April 2003 12:57 Go to previous messageGo to next message
I've got the RWD water pump & pipe assembly on my FWD motor. makes it all very easy, otherwise you'll need to use the FWD remote thermostat.
twincam_ke20
Castlemaine Vic
Re: Cooling sys rwd 4ag?!?! Tue, 08 April 2003 21:20 Go to previous messageGo to next message
Do u have any pics mate?!
why, dont i have to use a remote thermostat with the rwd set up?
And how much did the parts cost ya?
Toyota should be able to get them right? id rather get them new so they dont f**k up on me in a week or so Sad
Is it any harder useing the remote thermostat set up? or no?
thanks again..
sebta22
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 03:30 Go to previous messageGo to next message
Where did you get the RWD pump and cooling system from?
I am looking at the cooling system for my 4agte and it seems a bit of stuffing around to use the FWD poump and stat.
GZE-STYLE
Camden
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 05:45 Go to previous messageGo to next message
TE72_Turbo:
How is your alternator setup? Custom brackets ?
IRA11Y
Club Member
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 07:47 Go to previous messageGo to next message
Go to the articles section theres a fwd to rwd conversion guide
Grega
melbourne.victoria.austra...
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 08:11 Go to previous messageGo to next message
also check this. thanks to bill sherwood :
http://www.billzilla.org/4agwater.gif
TE72_Turbo
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 09:05 Go to previous messageGo to next message
twincam20:
the RWD water pump has the thermostat as part of the pump housing. You cant just buy the RWD pump & bolt it to the FWD motor, you need the complete pump & housing assembly.
Fortunately, another kind toymods member had purchased a complete RWD bluetop 4AGE, but only used the gearbox & engine mounts, so I bought the head, water pump & cooling system from that motor & fitted it to my FWD 4AG.
The remote setup works just as well, its just more of a fu(kup to setup initially, with more hoses needed, and you have to mount the thermostat somewhere, as it normally bolts to the FWD gearbox housing.
GZE-Style:
My alternator is on a custom mount. I had to mount it further forward to run off the front crank pulley row, as it fouled on the engine mount in my TE72.
I'll look for some pictures.
Phil
twincam_ke20
Castlemaine Vic
Re: Cooling sys rwd 4ag?!?! Wed, 09 April 2003 12:08 Go to previous messageGo to next message
thanks for ya help everyone Smile
think i'll do it like the dude on that tech articles "fwd too rwd"
seeing as i have a fwd remote thermostat and all and yeh, sounds/looks easy enough.
So is that all 'remote thermostat' is, it triggers a thermo fan when something opens and gets hot or what?!
IRA11Y
Club Member
Re: Cooling sys rwd 4ag?!?! Thu, 10 April 2003 08:03 Go to previous messageGo to next message
That "dude" is me Smile the remote thermostat is as the name states..it holds the thermostat which once the water is warm opens and allows the water to circulate around the engine but it does also have the sensor to trigger the thermo fan.
twincam_ke20
Castlemaine Vic
Re: Cooling sys rwd 4ag?!?! Thu, 10 April 2003 13:02 Go to previous messageGo to next message
hhehe cool
You got ne more pics of the plumbing if possible?
mac_surfer11@hotmail.com if ya do Very Happy
By using the rwd setup on the fwd motor, do you disregaurd the thermofan and use a "clucth fan" or what ever its called instead?
IRA11Y
Club Member
Re: Cooling sys rwd 4ag?!?! Fri, 11 April 2003 11:34 Go to previous messageGo to next message
You can use the clutch fan setup on the rwd but personally Id use a thermo fan, if you go clutch then make sure you use the RWD water pump as the FWD one wont handle the extra stress on the bearing
twincam_ke20
Castlemaine Vic
Re: Cooling sys rwd 4ag?!?! Fri, 11 April 2003 14:11 Go to previous message
Thanks for ya help IRA11Y Smile
So do u have any pics dammit Very Happy or anyone?! pleaseeeeeee
Previous Topic:brake conversion for corona?
Next Topic:How much $$ to refresh the diff
Current Time: Fri Nov 20 02:53:02 UTC 2026
Total time taken to generate the page: 0.010704040527344 seconds
