Toymods » Tech & Conversions » Celica 1ggte engine mounts
RA28
Celica 1ggte engine mounts Wed, 19 June 2002 03:29 Go to next message
I need the engine mounts from he NA 1G engines so I can put a 1GGTE in my RA28. What did thee engines come in and where is the best place to find them. Are they only at import wreckers or were the cars sold in Australia?
Or even better yet, Anyone got a set of these mounts??
Tim.
Re: Celica 1ggte engine mounts Wed, 19 June 2002 05:03 Go to previous messageGo to next message
Probably the best best would be early GZ10 or GZ20 Soarers, failing that you could try and find a GA61 Mk2 Supra (Celica XX). You guys over east don't have much luck with those though.
Dylo
icon4.gif  Re: Celica 1ggte engine mounts Wed, 19 June 2002 05:35 Go to previous messageGo to next message
G' DAY.
When i did mine, i had a spare NA 1GGE sitting round so it was easy, but my mate did the conversion too and he just got the mounts off me, and took it to an engineering joint and they whipped up some for him, moddeled on mine, only cost him $60 each, so it wasnt too bad, and there are factory looking!
Also a tip... when u get your metal mounts, you dont have to use spacers or anything tricky like that to hold the motor. Just go in2 Repco, and buy their version of the rubber mounts made for the 18R. They look nothing like the toyota ones, they are nolethane too Wink But they do happen to hold the 1G-GTE perfectly. It sits lower and further back compared to using the standard Toyo ones with 10mm spacers. (plus they are new!)
dcving
newcastle nsw
Re: Celica 1ggte engine mounts Wed, 19 June 2002 06:56 Go to previous messageGo to next message
Rolling Eyes anyone know which engine mounts to use for the 1ggte in in replace for a 3y engine for a hilux?
RA28
Re: Celica 1ggte engine mounts Fri, 21 June 2002 10:53 Go to previous messageGo to next message
dylo
You wouldn't happen to have any pictures or diagrams/measurements would you. I am going to have to get some made up so that would be helpful.
Tim.
Dylo
Re: Celica 1ggte engine mounts Sat, 22 June 2002 00:20 Go to previous messageGo to next message
Nope sorry mate, there were'nt any measurements taken by us in our conversions. And the mounts are now buried in all the mess under the engine, sorry! Rolling
The Engineering mob down here in ACT called Baxters did the mounts, and the just took my original soarer mounts and moddeled off them, one place quoted us obout $200 per mount, so look around coz we got them done for $60 per mount in the end.
stradlater
Arthurs Creek, Victoria
Re: Celica 1ggte engine mounts Sat, 22 June 2002 02:23 Go to previous messageGo to next message
Mate, you can get the steel fabricated mounts off the 1g-ge from the wreckers. I was quoted something like $80 for the both of them.
Fattony
Re: Celica 1ggte engine mounts Sat, 22 June 2002 03:59 Go to previous messageGo to next message
No Strad it was actually $90 dollars that I got quoted for the steel fabricated 1g engine mounts. But here is another point is that when i bought my 1g, i told the wrecker that i wanted these mounts with it, maybe try the place you got the engine.
stradlater
Re: Celica 1ggte engine mounts Sat, 22 June 2002 06:44 Go to previous messageGo to next message
NO, Actually I got quoted a different price completely independant of the one you told me.
ChuckLandwehr
Re: Celica 1ggte engine mounts Sat, 22 June 2002 09:41 Go to previous messageGo to next message
Hi Guy, The engine brackets off a 2T,or 3T are extremely close to what you want. Add a bit of metal fill a hole or two and redrill, and use the new nolathane mounts. Just make sure the angle is correct as from memory one side of the 2T/3T has a flatter angle.
Regards Chuck
RA28
Re: Celica 1ggte engine mounts Sat, 22 June 2002 10:06 Go to previous message
Damn!! What wreckers were you talkting about?!! I rung a heap the other day and no-one seemed interested! No-one had the mounts or the flywheel!
Tim
Previous Topic:Melbourne Spring/suspension GURU??
Next Topic:New engineering/modifications guidelines?
Current Time: Thu Oct 22 06:55:49 UTC 2026
Total time taken to generate the page: 0.0068650245666504 seconds
