Toymods » Tech & Conversions » Centrifugal supercharger BOV
SupraPete
Centrifugal supercharger BOV Wed, 09 April 2003 01:09 Go to next message
OK, I know the principals behind putting a BOV on a turbo car as there is still boost going in when the throttle closes and ends up slamming against the closed throttle butterfly and with repeated use can damage it.
With a positive displacement supercharger (roots type, or one from a 4AGZE/1GGZE) there isn't as much of a need as there is no more boost because the amount of boost is directly proportional to revs.
What about a centrifugal supercharger? They have a design similar to a turbo, so I'm not sure if it would boost when the throttle is closed, as it would be run on bearings, not directly on the crank speed.
My question is:
Would an engine with a centrifugal supercharger benefit from having a BOV??
Re: Centrifugal supercharger BOV Wed, 09 April 2003 01:14 Go to previous messageGo to next message
Uh, all superchargers (including centrifugal types) are run directly from the crank, and they all "run on bearings" as well.
I have heard of people running BOV's in blow-through centrifugal setups, but I'm not sure if this is beneficial or if it's just for the rice factor.
SupraPete
Re: Centrifugal supercharger BOV Wed, 09 April 2003 01:24 Go to previous messageGo to next message
Positive (or is it negative?) displacement superchargers fully enclose the air and force through x amount each revolution. Centrifugal ones have to spool up like a turbo to produce boost.
Re: Centrifugal supercharger BOV Wed, 09 April 2003 01:50 Go to previous messageGo to next message
Yeah, with centrifugal the boost rises in proportion with revs.
Provided you mounted it in the same way as you would a turbo before the throttle it would benefit as the compressor side of a centrifugal is exactly the same as a turbo.
[Updated on: Wed, 09 April 2003 01:51]
SupraPete
Re: Centrifugal supercharger BOV Wed, 09 April 2003 02:43 Go to previous messageGo to next message
Thats what I was thinking.
I've got a really nice HKS BOV that I pulled off my 7M, if I can fit a centrifugal supercharger in with the 1U I'll put the BOV back on.
Re: Centrifugal supercharger BOV Wed, 09 April 2003 08:34 Go to previous messageGo to next message
A centrifugal supercharger does not spool up anything like a turbo; the revs of the compressor are directly proportional to the engine revs. Yes they develop boost as an exponential function of rpm, but that's not the same as saying they "spool up".
Re: Centrifugal supercharger BOV Wed, 09 April 2003 11:39 Go to previous message
This is simple stuff! With any kind of mechanically driven blower, whether you need a BOV(damn I hate that term!) depends on whether the blower is mounted before or after the throttle. If the throttle comes first, there's no way in hell you can use one - obvious and simple. I've seen wallies try and put them on 4AGZEs and wonder why the hell they don't work.
BUT if the blower comes BEFORE the throttle, you MUST have something, ESPECIALLY if it's a positive displacement type - this is because after the throttle shuts, the engine is still driving the blower, and it will build up enormous pressure in the inlet pipework, if you're lucky blowing off a hose or less lucky bending the throttle (with the appropriate results!)
Simple - a throttle before the blower (such as 4AGZE) cuts off the air, therefore there's no air to vent (otherwise the engine would still be going hard!).
Previous Topic:intercooler pics
Next Topic:18RC leaded or unleaded?
Current Time: Thu Nov 19 15:10:01 UTC 2026
Total time taken to generate the page: 0.0077919960021973 seconds
