Toymods » Tech & Conversions » what oil and oil filter to use with my 4agze engine
sprinterboy4agze
what oil and oil filter to use with my 4agze engine Thu, 10 April 2003 21:12 Go to next message
what would i say get a oil filter for my 4agze engine can i use the oil filters used on the blue top or the red tops? and spark plugs as well
Sprinter
Re: what oil and oil filter to use with my 4agze engine Fri, 11 April 2003 04:22 Go to previous messageGo to next message
Use the 100kw 4age oil filter. I believe the 3SGTE filters also fit but I can't remember the part number. Check the other thread about Urgent part numbers needed.
I use Mobil 1 5w50 (not the 0w40) and have since I've had it in.
Denis
xpimp
melbourne
Re: what oil and oil filter to use with my 4agze engine Fri, 11 April 2003 05:10 Go to previous messageGo to next message
Spark plugs are platinium plugs
Bursons can look it up for u in their catalogue
Flem
cambo
Re: what oil and oil filter to use with my 4agze engine Fri, 11 April 2003 10:07 Go to previous messageGo to next message
toyota 90915YZZC4 oilfilter 4age& 9043012031 sump plug washer just for the hell of numbers 90915YZZB4 3sgte
[Updated on: Fri, 11 April 2003 10:10]
sideshow
Re: what oil and oil filter to use with my 4agze engine Fri, 11 April 2003 13:22 Go to previous messageGo to next message
ryco oil filter for all 4ag engines is z386
Rolla Boy
Club Member
Sydney, NSW
Re: what oil and oil filter to use with my 4agze engine Sat, 12 April 2003 03:45 Go to previous messageGo to next message
I have a 100kW 4AGE and I work at Toyota...
I use:
Oil Filter: C4
Oil: Toyota Genuine 20w50 SJ/CF (It's an extremely good oil to use)
Spark Plugs: NGK
Air Filter: Standard
feral4mr2
Bundaberg, Qld.
Re: what oil and oil filter to use with my 4agze engine Sat, 12 April 2003 11:24 Go to previous messageGo to next message
Freak
Ryco Z386 oil filter. (all the 4age engines use the same oil filter).
Penrite HPR15 oil.
NGK BCPR5EY-11 V-groove option, dont use platinum plugs. waste of money, the fuel is not good enough for them in OZ.
Rolla Boy
Club Member
Sydney, NSW
Re: what oil and oil filter to use with my 4agze engine Sat, 12 April 2003 17:38 Go to previous messageGo to next message
feral4mr2 wrote on Sat, 12 April 2003 21:24
The 4AGE uses platinum plugs standard... They are to be replaced at 100,000km intervals... You must not use normal plugs in the 4AGE... Being a 4AGZE, i'd say the same thing... Use Platinum plugs... Replace them every 100,000kms...
feral4mr2
Bundaberg, Qld.
Re: what oil and oil filter to use with my 4agze engine Sat, 12 April 2003 21:41 Go to previous messageGo to next message
mate i have used V-grooves in my 4age and 4agze and 4agte with-out any problems (i have owned my car since 1995, i have a good idea what works and what doesnt).
and if you ask me the car goes exactly the same as it did with the way overpriced platinum plugs. i do not get any better performane or fuel economy by forking out $80 (or what ever they are worth now, it's been sooooo long since i bought some)for platinum spark plugs.
i have also done my research, and talked to many mechanics about it. you can use other plugs than platinum ones, and i recomend the V-groove NGK's.
what octane fuel do they have in Japan where the engine is built and ECU factory programmed?
Rolla Boy
Club Member
Sydney, NSW
Re: what oil and oil filter to use with my 4agze engine Sun, 13 April 2003 02:35 Go to previous messageGo to next message
Fair enough... I've just heard that you shouldn't use normal sparkies where they come platinum from factory...
And just out of interest, how often do you replace the normal plugs??? Every 40,000kms???
Blown86
Re: what oil and oil filter to use with my 4agze engine Sun, 13 April 2003 04:19 Go to previous messageGo to next message
The only advantage with platinum plugs is they last a long time.
Any lead in fuel will destroy platinum plugs.
The advantage with standard plugs is you can file them and re-gap them a couple of times ( probably not the v groove type)and they're cheap.
If you do much track work check the plugs before every track session, otherwise every 15000 - 20000 K's.
Jap fuel is 100 RON ULP.
[Updated on: Sun, 13 April 2003 04:23]
Flem
cambo
Re: what oil and oil filter to use with my 4agze engine Sun, 13 April 2003 08:45 Go to previous messageGo to next message
And the battle is on, what the manufacture recommends vs the boys whos tryed it.As for me being employed by toyota id say goes with boys who's tryed it.Why ? In most cases the recomendation is for the customer so the plugs are not getting changed every 40,000km's (in which case the 4afe and in 20,000kms for the 4afc)With the platinums they last 100,00kms, (try changing the plugs in a v6 camry/avalon every 40,000km's when the car is hot).And while on the topic which is better try running 26psi in those tyres which most toyota light vehicles say ...its only for the ride quality and destroys the tyres too.
sikmr2
Re: what oil and oil filter to use with my 4agze engine Sun, 13 April 2003 10:45 Go to previous message
feral4mr2 wrote on Sat, 12 April 2003 20:54
Freak
Penrite HPR15 oil.
Yep the platinum plugs are a waste of cash, my gze had them in when i first got it and after a couple of weeks they were stuffed, and i never put anything less than premium 98octane fuel in. And at less then a quarter of the price of platinums the NGK's are the best option. Who really cares if ya have to change them more often Very Happy
Previous Topic:Cheap Oil
Next Topic:rear wheel disk brake conversion for sa63 celica
Current Time: Thu Nov 19 12:13:14 UTC 2026
Total time taken to generate the page: 0.0061337947845459 seconds
