Toymods » Tech & Conversions » Corona stuts into KE30
EMP-2TG
Carlingford, Sydney
Corona stuts into KE30 Sat, 12 April 2003 07:00 Go to next message
i know i can be done
i just need to know
1. what model stuts
2.do i need the steering arms?
3 anything else i need to know b4 i do it
Re: Corona stuts into KE30 Sat, 12 April 2003 15:35 Go to previous messageGo to next message
you'll get positive camber....
dunno exactly, measure the bolt spacing at the knuckle, see what size your balljoint is then hit the wreckers Wink
good luck.
demuire
Ipswich
Re: Corona stuts into KE30 Sun, 13 April 2003 02:32 Go to previous messageGo to next message
I have Corona struts in my KE55.
You want XT130 struts, and you'll need the steering arms too. You can't use the Corona springs or top spring seat (too big) so use AE86 springs and spring tops, with your original Corolla strut top. And yes you'll get a slight positive camber.
If you want your car to be standard ride height use lowered AE86 King springs. If you want to get it lowered you'll need to get shorter stroke shocks (as the lowered springs are already barely captive), you can either modify your shocks or get something like AE92 shocks and put spacers in so they fit. This is what I'm thinking of doing (I've got the lowered AE86 springs at the moment, I want to go lower).
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 03:09 Go to previous messageGo to next message
thanks Smile
just what i wanted to know
im thinking of getting adjustable coil overs for this as well
so that will be small enough
and ill get the strut tube shortend as well
thanks Smile
demuire
Ipswich
Re: Corona stuts into KE30 Sun, 13 April 2003 04:50 Go to previous messageGo to next message
Mmm, yes. Getting coilovers has crossed my mind. And perhaps getting the tubes shortened...
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 05:44 Go to previous messageGo to next message
im going to send a email to ae86world.com
the sell a coil over kit for $230 or somthing
demuire
Ipswich
Re: Corona stuts into KE30 Sun, 13 April 2003 08:10 Go to previous messageGo to next message
Any idea what's the difference between the cheaper press on aluminium one and the more expensive weldable steel ones? How much does it cost to get the struts shortened?
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 09:28 Go to previous messageGo to next message
the press on 1's u need to weld a spacer under the alloy bit and it butts up against it as far as i know
there is a good artical on club4ag.com about it Smile
cost to shorten
maybe $10 for the welding and thats it
click the link it will show all Smile
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 09:34 Go to previous messageGo to next message
also have a look here at a toymods post about a setup
maybe as him some questions as well
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 09:37 Go to previous messageGo to next message
as u have posted up in that post i see you know about it
demuire
Ipswich
Re: Corona stuts into KE30 Sun, 13 April 2003 11:53 Go to previous messageGo to next message
That is like... WAAY COOL Smile Thanks for that link!
One thing I'm wondering: If you're going to cut 40mm out from above and below (20mm either way) the spring seat, why bother cutting the spring seat out in the first place? Wouldn't it be easier to just cut the top section off and the bottom section out and then weld the top and bottom together?
I wonder what the legalities of this are... Cause according to the Vehicle Modification Guide you aren't allowed to cut or weld any suspension, steering or axles... But then again lots of people run shortened axles (and have had them engineered to be legal)... I wish I had a friend who was an engineer!
EMP-2TG
Carlingford, Sydney
Re: Corona stuts into KE30 Sun, 13 April 2003 22:27 Go to previous message
yeah how nice is it Smile
im gunna do the same i think for mine
dunno how legal it would be tho
who is gunna look?
ill keep the stock just incase some1 crys about it i guess
Previous Topic:Tree Sap on Primer
Next Topic:Which Diff for the 1jzgte??
Current Time: Thu Nov 19 18:39:00 UTC 2026
Total time taken to generate the page: 0.036328077316284 seconds
