Toymods » General Car Talk » Early Celicas
TurboRG
Nor Calif USA
Early Celicas Wed, 19 June 2002 18:53 Go to next message
What kind of 1/4 mile times are you running
and what kind of mods have you done to your
cars?
I have a RA20 (1971) and a RA21 (72)
they both have 18RGs in them
but I have only ran one of them down the 1/4.
my 72 has ran a 15.5s with No traction ( 60ft 2.4s).
I know it can do better then that.
Mods done to the car.
18RG
ported head and intake manifold
stock 40mm carbs
304/288 cams
TRD hearder/extactor
forged 10.5 pistons
2.5 inch exh.
5 speed trans
4.3 rear end
16s rims that are 7 wide tire is
8.5 wide.
my (71) is a turboRG
I have a custom EFI manifold and a stock EFI
manifold.
20R forged pistons
stock cams
ct26 turbo
custom 3 inch exh.
Ford 2.3 Turbo ECU
4 speed trans
Ford 9inch rearend 4.56 gears
that should run 12's
What about you?
dorikin
NE Melbourne
Re: Early Celicas Thu, 20 June 2002 06:01 Go to previous messageGo to next message
1974 TA22 with 1984 4AGE TVIS MAP conversion... 2in exhaust from stock ex manifold and k&n pod filter, remapped stock computer. Sprinter T50 box, stock TA22 rear end with T292 centre. done 16.5 measured with Race Technology AP22 (think G-tech, but about 100000000 time better)
thetoyman75
Club President
icon6.gif  Re: Early Celicas Sat, 22 June 2002 15:00 Go to previous messageGo to next message
TurboRG,
Tina's TA22 is a 1973 model with a Mild 2TG. For the complete specs follow this link:
http://www.toymods.org.au/tina_try.html
Best Run down the Qtr so far is a 16.052sec Pass at 85.45 MPH.
Still needs a lot of tweeking but should see the 15 Sec bracket if all goes to plan.
15.5 from the 72 is a Nice time given the Extra weight of the 18RG. They are quite a bit heavier than there 1600cc equivalent.
Regards,
[Updated on: Sat, 22 June 2002 15:01]
sbyder
Ipswich QLD
Re: Early Celicas Sun, 23 June 2002 09:56 Go to previous messageGo to next message
At a test and tune at willowbank last summer, my RA28 celica with 0.5mm of tread on rear tyres(seriously, i'm saving for turbo- but now i know u need tread) with 25kg sub-box combo and amp-ie: full street trim, pulled:
1st run: No result recorded- they stuffed up.
2nd run:16.83 @ 89mph
3rd run:16.95 @ 81mph
The 1st run was embarassing: i got told to put my window up on the line- I was very nervous being my 1st time and i forgot, then when i was winding it up the light went- me bad!, and then I fluffed second gear. The only good thing was i still wipped the escort in the micky thompson lane.
The 2nd run was my best on the night, although I had traction loss until 5-6000prm in second and a chirpy in 3rd (with soft launch) and not flat changing.
The 3rd run was all-out. I wanted to go faster so i launched hard, flat changed and subsequently lost traction till end of third whilst backing off the throttle, hence the time.
The moral of the story: I U WANT TO GO FAST HAVE ENOUGH POWER, AND ENOUGH TREAD. AND/OR GET SLICKS!!!
I honestly believe i should get into the mid/high 15's. Next time i'll have new soft tyres.
PS: how much do stock RA28 celica meant to weigh?
TA22-3SGTE
MACKAY
Re: Early Celicas Sun, 23 June 2002 12:30 Go to previous messageGo to next message
1971 ST TA22 Just had a run today at the strip
12.64 sec @ 119.25 on street tyres - no traction in 1st & 2nd
Mods ST165 GT4 motor running 17psi boost !
Trevor
justinharwoodran
Re: Early Celicas Fri, 28 June 2002 23:31 Go to previous message
18.5
engine stock
radio going (eating ice cream)
boys pissing themselves (track marshals not happy)
Justin
ps Barney Bananna Paddle Pop from memory!
Previous Topic:Where to get 2nd hand AE82 workshop manual?
Next Topic:Attention soft roader owners!!!
Current Time: Thu Nov 19 05:51:37 UTC 2026
Total time taken to generate the page: 0.0051929950714111 seconds
