Toymods » Tech & Conversions » Fried Fuel Pump
xpimp
melbourne
Fried Fuel Pump Tue, 15 April 2003 12:50 Go to next message
ERRRGH just when i had the conversion FINISHED it goes and roots itself Sad
My V8 fuel pump (external commodore) one fried... now I am wondering if this is cause my fuel lines are too thin Sad What do other ppl do, i was using the standard 4ac tank with original lines (except i ran a thicker pipe after the pump but not on the 30cm before)?
Any ideas would be MUCH appreciated
XPimP
Twinky
N.S.W
Re: Fried Fuel Pump Tue, 15 April 2003 12:55 Go to previous messageGo to next message
4ac main line is tiny dude, get your self some twinky ones Very Happy
xpimp
melbourne
Re: Fried Fuel Pump Tue, 15 April 2003 12:56 Go to previous messageGo to next message
What did u do mate?
cause i did replace all the pipe after the pump but cant figure out a good way of doing it inside the tank
Twinky
N.S.W
Re: Fried Fuel Pump Tue, 15 April 2003 13:10 Go to previous messageGo to next message
Oh ok, well i just used the stocker fuel pump and lines (for now). Works ok. My only problem is what i wrote about bearing noise.
I seen your site, FARK thats a meaty spacer, i think mine is about half the size. LHS Drive shaft is miles away now but NOW the RHS is very close Mad
I hope to frabricate custom brackets for the cross member to eliminate any spacers etc, a little further down the track.
I just hope my problem is sorted. Least the motor is under warrenty
[Updated on: Tue, 15 April 2003 13:13]
xpimp
melbourne
Re: Fried Fuel Pump Tue, 15 April 2003 13:16 Go to previous messageGo to next message
Do u know if my tank can be modded easily for an internal pump???
Yer the spacer is big but its still within legal ground clearence and engineer seemed semi happy with it LOL but it needs to be that big if u want it to be at perfect height Smile
But this pump is really pissing me off now, cause i want to drive it now Sad
Twinky
N.S.W
Re: Fried Fuel Pump Tue, 15 April 2003 13:20 Go to previous messageGo to next message
Your best bet would be to get a twincam fuel tank.
Im scared to drive mine cause it might blow up. Crying or Very Sad Crying or Very Sad Fuck it launches though. Smile
Re: Fried Fuel Pump Tue, 15 April 2003 14:32 Go to previous messageGo to next message
heya,
how is the crummydore pump like for sucking the fuel? i hear rumours that many EFI pumps are not good at scavenging fuel from the tank, and then cavitate, run dry and blow up... if you surge tank it and get a lifter pump, there's no chance of running dry.
if you run the fuel rail return line to the surge tank, you only need a small pump to supply the surge tank (as it replaces the fuel the engine actually uses, which will be much less, on average, than your injector size)..
at worst, get a low pressure pump which is rated at say 10% more flow than the external pump is rated _at fuel rail pressure_ (it won't flow more than that unless your rail pressure goes down.. and that's all bad) and then just run it in series with the EFI pump. the low pressure pump will be better at scavenging theu the little lines to the tank, and you could T the rail return to between the two pumps to reduce the work done by the first pump (so it can be smaller/cheaper)
anyhoo, hope this gives ya some ideas...
ps, there is a VL turbo pump on ebay atm for about $60...
xpimp
melbourne
Re: Fried Fuel Pump Tue, 15 April 2003 15:36 Go to previous message
Sweet thanks for ur reply...
been a bad day Sad hopefully i can fix this thing soon Smile
The pump did run sweet, i thought it was really good until now, didnt seem to be dry Sad doesnt seem to have air in the pipe so i have no idea why it died, maybe the smaller lines killed it
Thanks, ill have a look at enlarging the pipe (dont know how im gonna do it but im sure theres a way)... And ill look at getting a new pump asap
-XPimP
Previous Topic:ATF cooler.. too small ? (A34*E)
Next Topic:ae86 rear brakes
Current Time: Mon Nov 2 12:49:53 UTC 2026
Total time taken to generate the page: 0.0040709972381592 seconds
