Toymods » Tech & Conversions » supra and chaser 1jz sumps & oil levels
supra and chaser 1jz sumps & oil levels Wed, 16 April 2003 04:59 Go to next message
I heard it mentioned on another thread that when you change 1uz oil sumps (say from mid to rear) then you also need to change dipsticks, as the oil levels change.
I was wondering if the same is true of a 1jz. I've got a supra 1jz with a chaser sump on it, and I'm fairly certain the dipstick etc is all from the supra 1jz.
Pete
gold coast
Re: supra and chaser 1jz sumps & oil levels Wed, 16 April 2003 10:02 Go to previous messageGo to next message
They have totally different length dipsticks and tubes.
I have both sumps on the shelf and was amazed that there was a difference.
Re: supra and chaser 1jz sumps & oil levels Wed, 16 April 2003 13:24 Go to previous messageGo to next message
ah.
er.. hrm. crap.
do you know which would read higher on the dipstick?
'cause if the supra one would read lower, that would explain my oil usage problem very easily, without pulling it apart to look at the valve stem seals. would be a simple matter of too much oil.
(in which case, I've probably done a deal of harm to the seals regardless)
Pete
gold coast
Re: supra and chaser 1jz sumps & oil levels Wed, 16 April 2003 13:48 Go to previous messageGo to next message
I will measure them for you tomorrow(thurs) so you can check what you have.
Re: supra and chaser 1jz sumps & oil levels Wed, 16 April 2003 13:55 Go to previous messageGo to next message
much appreciated Smile
Pete
gold coast
Re: supra and chaser 1jz sumps & oil levels Thu, 17 April 2003 13:03 Go to previous messageGo to next message
http://home.austarnet.com.au/petew/D.jpg
Top one is JZA 70, Bottom is JZX81.
Effective Length JZA70: Stick = 557 mm Tube = 490 mm
Effective length JZX81: Stick = 585 nn Tube = 530 mm
If you use a chaser tube and stick in a JZA 70 you will have 12mm less oil height. If you swap back the other way you will have 12mm too much.
Dipstick Eff length is from the tip to where it seats on the dipstick tube.
rogue-vl
Casino
Re: supra and chaser 1jz sumps & oil levels Fri, 10 December 2004 12:17 Go to previous messageGo to next message
AHhh Found it!
Now just to make sure, I have a front sump using the JZZ30 rear sump dip stick, am I right in asuming that this will indicate 12mm too much oil?
Ben
cilyka
Re: supra and chaser 1jz sumps & oil levels Sat, 11 December 2004 02:51 Go to previous message
easier way is to just find out how much oil is needed for the motor you have
then its simply just a matter of measuring how much oil you are putting in Very Happy
Previous Topic:1JZ Front/Rear Sump Dip stick differences
Next Topic:2rz bellhousing to 3rz engine
Current Time: Sun Oct 25 20:02:45 UTC 2026
Total time taken to generate the page: 0.0045499801635742 seconds
