Toymods » Tech & Conversions » What are the costs and dificulties of a 4afc to 4age conversion?
kemicalx
Geelong.Vic.Au
What are the costs and dificulties of a 4afc to 4age conversion? Thu, 17 April 2003 05:05 Go to next message
I want to replace the 4AFC in my CS Seca for a red top 100kw 4AGE. Presuming i already have the 4AGE, gear box and looms. What other items am i going to need to get the conversion done and how much would they cost second hand? The acctual cost of installing the stuff isn't a problem. So basically my question is
How much would this conversion cost excluding Labour, Engine, Gear box and loom.
Thanks alot Smile
[Updated on: Fri, 18 April 2003 09:11]
kemicalx
Geelong.Vic.Au
Re: What are the costs of a 4afc to 4age conversion? Thu, 17 April 2003 09:08 Go to previous messageGo to next message
anyone?
kemicalx
Geelong.Vic.Au
Re: What are the costs and dificulties of a 4afc to 4age conversion? Fri, 18 April 2003 09:15 Go to previous messageGo to next message
come on people...
i presumed it would be a peice of piss to swap over. Because the redtop 4age's are in the same year SX version of the seca.
celicaboy_2000
Lismore, NSW
Re: What are the costs and dificulties of a 4afc to 4age conversion? Fri, 18 April 2003 09:49 Go to previous messageGo to next message
Hey, The engine mounts are basically the same so it will bolt straight in. U will have to put a electric fuel pump i'd recommend a surge tank or replace the fuel tank with a original fuel tank out of a injected corolla also you will have to put in a return fuel line. Just a quick summary. It would be a pretty easy swap.
kemicalx
Geelong.Vic.Au
Re: What are the costs and dificulties of a 4afc to 4age conversion? Fri, 18 April 2003 09:55 Go to previous messageGo to next message
we would it be wiser to buy a front cut of an SX corolla, than just the motor GB and loom?
Flem
cambo
Re: What are the costs and dificulties of a 4afc to 4age conversion? Sun, 20 April 2003 05:47 Go to previous messageGo to next message
get front cut up in sydeny some importers dont even do front cuts of the 100kw corollas they are into the 20V's up in brisbane ASiAN ATUO SPARES DO A 20V front cut for only $1750 not saure about shipping though.// Note the 4afc has a different gearbox compared to the 4age C50 vs C52. The ratios are different
kemicalx
Geelong.Vic.Au
Re: What are the costs and dificulties of a 4afc to 4age conversion? Sun, 20 April 2003 07:05 Go to previous messageGo to next message
do front cuts generally come with a GB?
Re: What are the costs and dificulties of a 4afc to 4age conversion? Tue, 22 April 2003 02:00 Go to previous messageGo to next message
front cuts are the complete car from the a pillars forward. Only sometimes they dont come with panels (bonnet guards etc).
You might have to change radiator to get the outlet in the position that suits the 4age.
Get a CSi, SX or GTi fuel tank and lines. EFI pump is internal in the tank. $250
Get a CSi, SX, GTi or CS-X dash with tacho and engine light warning. $100
There is more... but seriously - its easier to get a frontcut, everything is there and untouched. That said you would be VERY hard pressed to find a 4age frontcut. 20V and GZE front cuts are the only thing you will find.
kemicalx
Geelong.Vic.Au
Re: What are the costs and dificulties of a 4afc to 4age conversion? Tue, 22 April 2003 02:42 Go to previous messageGo to next message
cheers dude, that said. presume i pick up a 20v front cut for $1750 how many other costs are going to be added to that mto get it in my car? (once again excluding labour)
kemicalx
Geelong.Vic.Au
Re: What are the costs and dificulties of a 4afc to 4age conversion? Tue, 22 April 2003 02:46 Go to previous message
oh btw i all ready have the csx dash so that wouldn't be a cost Smile
Previous Topic:mark3 87 turb, how much boost is enough boost?
Next Topic:7MGTE oil cooler hose size?
Current Time: Wed Nov 4 05:06:37 UTC 2026
Total time taken to generate the page: 0.0067050457000732 seconds
