Toymods » Tech & Conversions » Light problem
HYPA-NOVA
Brisbane QLD
Light problem Thu, 17 April 2003 08:34 Go to next message
ok my ta23 has a problem with the lights, on low the two corner lights stay on, on medium only the two corner lights turn on and on high beam all six lights turn on.
are two circle lights supposed to be on in medium beam? if so how do I fix it?
Re: Light problem Thu, 17 April 2003 14:58 Go to previous message
i don't know for sure, but i think your outside circle lights should be on at medium.
check fuses first,
then pull out the globes and check the low beam filament with a multimeter.
if the globes check out ok, check the plugs for voltage with the different settings on the switch.
after that, trace the wiring and connectors, as there must be a break somewhere, possibly the inside switch, possibly a relay if you have them?
basically be methodical, check the easy stuff first, and write down the things you have checked (always helps later)
good luck,
Previous Topic:Polishing alloy engine parts/components
Next Topic:Crank Scraper for Toyota 4A-FE / 4A-GE engine
Current Time: Wed Nov 4 08:05:57 UTC 2026
Total time taken to generate the page: 0.091704845428467 seconds
